How about a MR-BIOS ROM file repository?
Reply 142 of 441, by Anonymous Coward
I tried SiS Rabbit, C&T Peak/DM and Topcat MR-BIOS. None of them can enable the cache on the boards. It's kind of disappointing because these are all high performance chipsets that could have really benefited from MR-BIOS tweaks. Only the Topcat chipset can be excused, because this chipset doesn't natively support cache...that comes from a 3rd party controller.
Reply 143 of 441, by Cyrix200+
I noticed a 386SX motherboard on an auction site and asked the seller for a BIOS dump. He helped out 😀
I am not sure this one was already found before, the board has the Acer/ALi M1217 chip. BIOS ID is V1.41-ACER310.
1982 to 2001
Reply 144 of 441, by maxtherabbit
I just tried the generic 286 MR BIOS on my 286-15. The system was 100% working on the AMI BIOS but with MR BIOS it hangs when trying to load Win 3.1. Anyone seen this before? It works just fine in DOS
Reply 145 of 441, by keropi
Cyrix200+ wrote on 2020-05-12, 11:43:
nice one Cyrix200+ !!!
Reply 146 of 441, by dionb
Woohoo, he did it!
Great job 😀
Reply 147 of 441, by Cyrix200+
dionb wrote on 2020-05-13, 22:07:
Woohoo, he did it!
Great job 😀
This is another one than the one you spotted not far from me. That seller wasn't so helpful unfortunately. I could have that image also, if I bought the PC with it 😜
1982 to 2001
Reply 148 of 441, by GL1zdA
Anonymous Coward wrote on 2020-05-02, 13:45:
Which SiS Rabbit board do you have? Because I planned to buy an EPROM writer and test in on my ASUS, but if it doesn't work I will skip this.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 149 of 441, by Anonymous Coward
My SiS Rabbit board is a fairly old one. Looks to be 1990 vintage. It was made by a company called CTI Electronics in Connecticut. Surprisingly the company is still around, but doesn't make PCs anymore. I might try contacting them since my board is not listed on TH99, but I am skeptical they have anything I need. In any case, it uses a Revision A Rabbit chipset, and has a clunky 1990 core AMI BIOS. The layout is quite similar to the Asus board you have. It appears to only support 1MB SIMMs and up to 128kb cache, but since I don't have a manual I can't say for certain. Strangely it won't accept DLC type CPUs at all.
The attachment AMI BIOS Motherboard & Intel i386 503-4L-I VINTAGE_1.JPG is no longer available
Reply 150 of 441, by evasive
Anonymous Coward wrote on 2018-03-19, 23:43:
http://www.elhvb.com/mobokive/Archive/Octek/3 … guar/index.html
Maybe someone can contact whoever is responsible for mobokive to see what happened to the Jaguar IV and V files. One is the MX chipset, and the other is for HT.
Speaking. What exactly are you looking for?
Reply 151 of 441, by evasive
appiah4 wrote on 2019-02-05, 07:04:
OK, guys, I am super excited to share this link with you.. Because I have either hit the MR BIOS Rom motherload.. Or I just found out something you all already knew and I'm getting all excited about nothing, but: http://www.elhvb.com/mobokive/archive/power_utils/cdroms.txt
And the CD contents are here: http://www.elhvb.com/mobokive/archive/power_utils/
There are literally dozens of MR BIOS roms here..
And I seem to have some more offline as well... Another indexing/deduplicating project... Sigh...
Reply 152 of 441, by Anonymous Coward
When you click on the link for the Jaguar IV MR BIOS, you get:
HTTP Error 404.3 - Not Found
Reply 154 of 441, by evasive
maxtherabbit wrote on 2020-05-13, 18:15:
What happens if you start windows with
win /s
as I have seen this posted as a fix/workaround elsewhere.
Reply 155 of 441, by maxtherabbit
evasive wrote on 2020-06-01, 19:24:
What happens if you start windows with win /s as I have seen this posted as a fix/workaround elsewhere. […]
win /s
Thanks for the suggestion but I long since rolled back to the AMI BIOS. Curiously I did find that Windows would start if executing and quitting MSD or SCANDISK prior to trying to open it.
Reply 156 of 441, by evasive
Going through the text files found this little gem
System BIOS for Gigabyte "GA-586ATE" motherboard (Intel Triton) […]
MR BIOS (r) V097B50Q Version 3.31
NOTE: This version 3.31 of the V097B50Q BIOS for the Gigabyte motherboard
replaces the previous version 3.30 dated 2/29/96 which contained support for
the wrong super I/O chip. This version 3.31 dated 5/7/96 supports the Gigabyte
motherboard containing a super I/O chip labeled SMC 1665IR but is actually
an ALI M5119 super I/O.
wait wut?
Reply 157 of 441, by bjwil1991
Is there a MR-BIOS for the SiS 85C460 (single chip) that is on a 386/486 motherboard? I looked at the spreadsheet on Page 6 that has this information:
Filename ------> BIOS string --------> Description
V072B400 -----> SIS_400 --------> 460,461V 386,486,Cx
Reply 158 of 441, by Anonymous Coward
That *seems* to be the one you need, but sadly we haven't found it yet.
It's a real shame that there were missing files from the latest dump, because many of the missing ROM images are for fairly common chipsets. Though, we should be extremely grateful for what we have (seems to be about 75% complete).
Reply 159 of 441, by DoutorHouse
evasive wrote on 2020-05-31, 12:34:
Was wondering if you have those ICL files mentioned on cd2. Thanks!
