DOSBox ECE (for Windows & Linux)
Reply 1081 of 1089, by CrossBow777
ripsaw8080 wrote on 2020-06-29, 21:45:
Mixer behavior depends on sbtype= and/or sbmixer= settings.
More detail here.
Then why does it not do it on regular DOSBox .74 or my SVM build I also use from time to time?
Midi Modules: MT-32 (OLD), MT-200, MT-90, SD-20
Reply 1082 of 1089, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I can only guess that it's due to different settings, e.g. you use sbtype=sb1/sb2 or sbmixer=false in those cases where Dune 2 is not affecting your mixer settings. Perhaps there is some confusion as to which .conf file is being used. You can check the current settings by typing "sbtype" and "sbmixer" at the prompt.
At my place, with default settings (meaning sbtype=sb16 and sbmixer=true) in official 0.74(-3) and SVN, Dune 2 (US floppy version 1.07) is changing the mixer settings. As you can see in the linked thread, the user there was encountering the described behavior.
Reply 1083 of 1089, by jaygame1
MT_ wrote on 2020-03-06, 12:09:
Yesterplay80 wrote on 2020-02-21, 15:42:
Srandista wrote on 2020-02-21, 15:05:
What was the last version with Pixel perfect scaling? r4301?
Yup.
Hi, Yesterplay80. Given that for many users like me,is the most/only interesting feature of DOSBox ECE compared with the regular official DOSBox, it would probably make sense to add a direct link to the latest build of DOSBox ECE that had pixel-perfect scaling, to the page of DOSBox ECE (dosboxece.yesterplay.net/en/ ). Thanks.
ECE no longer has pixel-perfect scaling!?
Reply 1084 of 1089, by igermi
I am using dosbox ece to run grand prix 2. I have a steering wheel and pedals for this game, and for a few years now I have been using it with the "timed = false" option because with cycles "auto" it makes the game play at the correct speed but the steering wheel drifts and acts up. If I reduce the number of cycles from "cycles auto" to say, "cycles 10000" the game runs EXTREMELY slow but the steering wheel does not get super Jittery and drifty.
Is there something I can do to make TIMED = true work? I get an awesome HUGE resolution with my steering wheel when I have it set to timed=true, compared to timed=false.
I've tried different settings with the cycles. 80000, 50000, and 30000. All three of these were too jittery with the timed = true setting.
EDIT: I THINK I FIXED IT.
I was using an older version of ECE (4205) I downloaded the new one (4356) and it does not jitter on TIMED = TRUE with cycles at "AUTO".
Thanks guys- sorry for the wild goose chase!
Reply 1085 of 1089, by Yesterplay80
jaygame1 wrote on 2020-07-04, 21:32:
It has, via the shader support that came with regular DOSBox. But it doesn't contain Ant_222's pixel perfect patch any longer, because he's focusing on dosbox-staging and his patch didn't apply to DOSBox SVN any more.
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
Reply 1086 of 1089, by jaygame1
Yesterplay80 wrote on 2020-07-06, 08:21:
So how would I go about enabling it, then?
Reply 1088 of 1089, by MrFlibble
jaygame1 wrote on 2020-07-10, 18:51:
I believe the pixel-perfect scaling equivalent is now done by using the built-in sharp shader?
glshader  = sharp
DOS Games Archive | List of free open source games | List of free closed source games
Reply 1089 of 1089, by PoulpSquad
Something I noticed with shaders is that they don't work 100% of the time, depending on the resolution.
For instance, running a program like Deluxe Paint at EGA 640x350 and drawing a circle results in an ellipse.
Running IntegerScaler and disabling scalers entirely fixes the aspect ratio, but it makes my computer pretty choppy and slow.
Impatiently waiting for a scaler that works as well as Ant_222's patch, or Staging with Fluidsynth/MUNT support...
Edit: Setting glshader = sharp seems to have fixed the aspect ratio issue I was having, but it's not integer-scaled.
Is there a way to force integer-scaling?
Edit 2: Forcing resolution to 4:3 (in my case, 1920x1440) apparently forces integer scaling, except anything above 640x480. I am not sure what else to try to have pixel-perfect, integer-scaled, aspect-accurate display...
