Reply 34902 of 52813, by 386SX
Today I found this untested mainboard, great looking, old battery becoming to leak acid but still on a single metal point and I'll desolder it today. The board model says UB433-DAVE Rev 1.1 the chipset is an ALi 1429 and built around 1994, 256Kbyte L2 20ns cache, 30 pin ram sockets, "AMIBIOS 486DX ISA BIOS 1993" and there's a metal marking name it E119697 on the back of the mobo PCB ..still have to test it, probably will not even work but have someone some equivalent manual/layout known for this?
I've alread searched online, few info with the same questions and still no schematics or jumpers manual found.
EDIT: I found that the Ami identifier number of the bios (read online should be this "40-0212-001235...") tells it should be built by the Formosa Industrial Computing, isn't it simply the FIC company? Still no more info about it and many jumpers on the mainboard.
    131.17 KiB
Reply 34903 of 52813, by MKT_Gundam
kolderman wrote on 2020-07-01, 00:18:
MKT_Gundam wrote on 2020-06-30, 23:42:
I got a V3 3000 AGP and a GF point of Veiw GT240 1gb 128bit model (https://www.techpowerup.com/108492/point-of-v … 40-accelerators). Both untested, costing 5 dollars each one.
Is the GT 240 "useful" for xp games unitl 2005?
A v3 for $5 is a steal. It appears the GT240 will handle XP games OK, although I prefer a GTX2/5 series: https://www.techpowerup.com/review/axle-gefor … -gt-240/18.html
The gt 240 at least is better than my old 64bit gt610.
I planning use it on my am3 sempron / or celeron 420 for a xp rig just for late and demanding win 98 and early XP games.
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 34905 of 52813, by Intel486dx33
Cyrix Reveal Math Co-processor
Its rated at 25mhz and I am going to pair it with an AMD 386sx-33mhz.
Should be okay right ?
Reply 34906 of 52813, by chrismeyer6
PC Hoarder Patrol wrote on 2020-07-01, 04:46:
chrismeyer6 wrote on 2020-07-01, 04:13:
I have that same supermicro board and it's great. Super stable and great performance.
Do you have a spec of your system, Thx?
Dual P3 850mhz
1 gig ram
GeForce 2 ti
SB Live! 5.1
9 9.5 gig Seagate 7200 rpm Scsi drives in raid 5
2x WD 120 gig ata 133 drives 1 has windows 2000 sp4 the 2nd has XP Pro sp3
Pci ata 133 controller card
Intel pro 1gig Ethernet card
2x DVD burners ide
Zip 100 drive
850 watt seasonic modular pay
Generic gamer window case from 2005 when I first built the system
4x aerocool DS 120mm fans
It's a awesome system and I love using it. Sadly I haven't used it in over a year and it's currently stored with our other stuff in my in-laws basement.
Once we finish our basement and I have my own area I'll have all my systems setup.
I'm pretty sure that's the full specs. Next time we're at my in-laws I'll double check the hardware.
Reply 34907 of 52813, by 386SX
386SX wrote on 2020-07-01, 10:20:
As suspected the board doesn't boot but cpu, cache, vga warm up.. I've no ISA debug cards but until I find some jumper table for this is difficult to say. No traces are damaged, already desoldered the battery and under it everything is more than ok.
I was looking at the TMC PAT48AV-1.40 a similar board, different layout but clearly the same general configuration but jumpers are different even if it's the most aproximately similar mb I've found online.. I changed both cpu, vgas, ram but I just left the cache for now..
Reply 34908 of 52813, by imi
so... I haven't posted a lot here lately... been saving up for a few bigger purchases for once ^^
not one... but two Commodore machines and my very first Amiga :3c
a Commodore PC10-III together with a beautiful green phosphor MDA screen, the screen has a surprisingly long afterglow
my phone camera doesn't do the green justice, it's a prettier shade IRL, less yellow-ish
224.87 KiB
206.27 KiB
to top it off an original Commodore branded Cherry MX Keyboard with one of the weirdest layouts I have seen ^^
205.9 KiB
and the single most expensive retro-purchase I have made so far, after many unsuccessful attempts of getting an Amiga 500 I just went ahead and got an Amiga 2000 instead :3
also recently bought a Microvitec Autoscan monitor that supports 15Khz perfect for the Amiga :3
225.39 KiB
not only that though, also stumbled upon this Amiga Cherry MX Keyboard as well at the same time, the case is strikingly similar to the PC keyboard above ^^, and since the 2000 came without any accessories I bit the bullet and just bought it (it wasn't cheap)
139.06 KiB
Reply 34909 of 52813, by imi
...continued...
why was this A2000 so expensive though?
because it has a GVP G-Force 030 accelerator / SCSI controller combo card inside :3
with 68EC030 and 68882 @40Mhz
225.35 KiB
182.19 KiB
and a "MacroSystem DeInterlaceCard" line doubler / flicker fixer with VGA output as well, wouldn't have needed that 15Khz monitor in hindsight, but it's still nice in case I ever decide to win the lottery and get more Amigas ^^
214.8 KiB
Reply 34911 of 52813, by devius
chrismeyer6 wrote on 2020-07-01, 14:32:
9 9.5 gig Seagate 7200 rpm Scsi drives in raid 5 2x WD 120 gig ata 133 drives 1 has windows 2000 sp4 the 2nd has XP Pro sp3 2x D […]
2x DVD burners ide
Zip 100 drive
Needs more drives 😆
Reply 34913 of 52813, by MMaximus
imi wrote on 2020-07-01, 15:49:
so... I haven't posted a lot here lately... been saving up for a few bigger purchases for once ^^ […]
Great haul! Is the monitor a 76bm13? I've been looking for one of these for a while now. Somehow they don't have a DB-9 connector at the back, do they?
Congratulations on the Amiga as well - very nice machine!
Hard Disk Sounds
Reply 34914 of 52813, by imi
thank you, yes, 76BM13/00E it has a DIN connector on the back, but luckily the DB9 to DIN cable was included
unfortunately there are markings and paint scratched into the top of the case, going to have to clean that up somehow, probably going to have to sand that off.
there was another keyboard included with the same markings ruining the case, but the pretty Cherry MX keyboard luckily only had ink markings that did get a bit into the plastic though and needed some persuasion to come off... so there's a bit brighter spot on the top left now but no damage to the texture really and it's barely noticable.
Wolfus wrote on 2020-07-01, 16:01:
Congratulations to your first Amiga 🙂 Long live the queen!
haha, time to slide into the bottomless pit of spending on amiga stuff now... I'm still missing a mouse before I can do anything though ^^
I seem to have a hundred different mice, but not a single Amiga mouse apparently ^^
Reply 34915 of 52813, by Wolfus
imi wrote on 2020-07-01, 16:45:
I use PS2 adapter and optical mouse. To be period correct, I still keep my original Escom A1200 mouse in drawer 🙂
Reply 34916 of 52813, by PC Hoarder Patrol
Dual P3 850mhz 1 gig ram GeForce 2 ti SB Live! 5.1 9 9.5 gig Seagate 7200 rpm Scsi drives in raid 5 2x WD 120 gig ata 133 drives […]
Dual P3 850mhz
1 gig ram
GeForce 2 ti
SB Live! 5.1
2x DVD burners ide
Zip 100 drive
A nicely balanced juggernaut 😀
Reply 34917 of 52813, by flupke11
For all the marketing bovine excrements Intel put out with their P4's, I still like the era, and S478 does have a sweet spot in my collection.
Here's a picture of the system I had in 2005:
204.94 KiB
I still have the Zalman Reserator 1, fully functional. The Abit IC7-Max3, together with the huge case, was sold not long after I moved house beginning of 2006.
It took me a while, but today I finally found an IC7-Max3 again (whee!), with a Northwood 3.2 and a whopping 4*1 GB of RAM.
Time to rebuild that 2005 pc!
Reply 34919 of 52813, by chrismeyer6
PC Hoarder Patrol wrote on 2020-07-01, 20:43:
Dual P3 850mhz
1 gig ram
GeForce 2 ti
SB Live! 5.1
2x DVD burners ide
Zip 100 drive
It really is a nice system and I can not wait to bring it home and use it again. It's one of my all time favorite computers I've built.
