First post, by SETBLASTER
did anyone here ever replaced the cpu socket on a motherboard?
i just got a dual socket370 board that has the tabs broken on one of the sockets. so the cooler cannot be installed.
its easy to know why, stupid intel used some kind of coolers with plastic tabs and a lever (equal to the pentium4 ones) that create an incredible amount of force. i had never seen cpu coolers like these ones
i do own a DEsolderind station. and also an hot air station. but i see this as a hell lot of work to do , besides i. not sure if socket370 replacements are available.
Reply 1 of 14, by luckybob
I've done it on a socket 8 machine. it REQUIRES a desoldering gun/station. I have a socket 370 board in the same situation as you, but its a project for a later day.
be patient, if you pull a single pad, the board is FUBAR. go slow, be gentle.
Reply 2 of 14, by mt777
Desoldering from pc motherboards is usually annoying (due to tight holes and and multi-layers pcb).
Another approach: you can find heatsinks with Patent (without clips, only use screws to join heatsink with cpu) but with this way cpu is never perfectly aligned to socket.
I did it with Nexgen socket.
Reply 3 of 14, by SETBLASTER
mt777 wrote on 2020-07-24, 22:26:
hi can you show me a picture of such heatsinks?
Reply 4 of 14, by Horun
Curious if only one of the main tabs is broken ? Or are two broken ?
My socket 370 have two tabs each side meaning you can use one of two different heatsink types, one clamps on mid tabs (like your heatsink picture) other uses the offset tabs. Can you post a picture ?
Reply 5 of 14, by SETBLASTER
Horun wrote on 2020-07-25, 02:05:
sadly, both broke
Reply 6 of 14, by Horun
SETBLASTER wrote on 2020-07-25, 02:10:
sadly, both broke
Can you post a picture ? Maybe someone can come with an alternative to replacing the socket ( I see also that as the very last choice due to the chances of board damage)
Reply 7 of 14, by Repo Man11
If you still have the bits, J.B. Weld epoxy (the original, not the fast dry) would be worth a try.
Reply 8 of 14, by shamino
A long time ago I remember an eBay seller who used to liquidate unused computer parts in bulk, and one of the items that came up was a box of something like 144 socket-370 ZIF sockets. I kind of wish I had bought that, but it seemed pointless at the time since I couldn't install them, and I still can't.
Years ago there was a post by mockingbird about pulling the plastic socket off the board, leaving the pins behind and then sticking a new socket over them.
Re: Socket 370 vs Slot 1 performance
I still need to try that, nothing really came up that provoked me to get that adventurous.
I wouldn't be brave enough to try it on something valuable like a dual CPU board though.
The easier workaround is to permanently epoxy a heatsink to the CPU and hope the socket will grip it tightly enough that it doesn't fall out. Or try epoxying the broken plastic if you still have it, as Repo Man suggested.
Reply 9 of 14, by luckybob
You can still buy NOS s370 cpu sockets on ebay.
Reply 10 of 14, by mt777
Two different heatsinks. Pink heatsink is more designed to socket7 but I had in the past a bigger this kind version
Reply 11 of 14, by Repo Man11
I think a Lin Lin socket adapter would work here, but I just did a quick search, and it seems they're very difficult to find. Slocket adapters are cheap, so one of those would be a good source of a donor socket if you want to try that.
Reply 12 of 14, by bytesaber
Today I learned that these sockets are just glued on. I like socket 370 for the easy heatsink/fan replacement. But knowing that my tower case is causing a large heatsink to just hang or pull against a glued on socket makes me question. Is this eventually going to fall off?
In the event of a broken tab (or fallen off?) socket 370, is there a method to make the replacement socket more secure? There doesn't appear to be any holes around it to put a rear support bracket behind the motherboard.
Reply 13 of 14, by nhattu1986
I remember seeing someone in this forum fix the broken tabs of the socket 370 by
- drilling 2-3 hole on the part when the tab is broken using pcb drilling bit by rotate it by hand
- put the small wire into the hole and fill it with eproxy for support, like you are using rebar to reinforce the concrete
- then he re-create the tab by manually molding the eproxy with the support bar
the result look pretty good imo.
a quick search show the exactly thread: Socket 370 repair, restoring a missing tab
Reply 14 of 14, by oh2ftu
In case anyone goes for a socket replacement, get a new socket. If you intend to use a donor-socket, don't use too much low-melt solder. It's a PITA to remove and clean MANY individual pins from the socket.
There are sockets available, but the shipping costs made it a no-go for me
