Reply 35520 of 53137, by Horun
Mephusto wrote on 2020-08-18, 16:30:
more of the pictures caused they wouldn't all fit. From what I can tell it might be a 486 under the heatsink. The XC87SLC-33 app […]
more of the pictures caused they wouldn't all fit. From what I can tell it might be a 486 under the heatsink. The XC87SLC-33 appears to be a maths coprocessor for a Cyrix or Texas Instruments 486 i think from the info i can find online. It said something about a hybrid 386/486 but i got lost at that point
edited for more info instead of making another post
"psu.jpg"
cant figure out this psu
That was common back in the 90's, would label all the variants. It could be any one of those models/wattage. You would need to remove it and check for other labels which should tell which it is. Even if just a 150 watt is more than enough for any 386 as long as you do not load up too many harddrives. I would remove the PSU and check it over well in and out, would examine the insides carefully for bulging/leaking caps, etc (and take hi-res pictures too)...
Reply 35521 of 53137, by H3nrik V!
Mephusto wrote on 2020-08-18, 20:37:
debs3759 - thank you, i got confused i thought that both 386dx and 486dx had the fpu...whoops 🤣 ill have to look into getting one once I am able to test that they work
You don't need an FPU to run the board. Lots and lots of 386 systems didn't have one back in the day. It only made sense for big spreadsheets or advanced maths.
Reply 35522 of 53137, by Miphee
Time to stock up more on 478-939-775 mainboards before they become too expensive!
(quite a few caps need replacing)
    1.91 MiB
    1.8 MiB
Reply 35523 of 53137, by Oetker
Miphee wrote on 2020-08-19, 08:25:
A friend of mine had one of those boards with a molex power connector on them, he used it not to power the board but to run a case fan...
Reply 35524 of 53137, by Miphee
Oetker wrote on 2020-08-19, 08:28:
I've never seen such a feature before, it has a red LED next to it that lights up when I connect a card that needs more power.
Reply 35525 of 53137, by dionb
H3nrik V! wrote on 2020-08-19, 03:25:
Indeed. There is a really short list of DOS games that use it:
Begin, A Tactical Starship Simulation
SimCity
Falcon 3.0
MS Flight Simulator
Scorched Earth
Pub Pool
Stunt Car Racer
Quake
Out of that lot, the only one that would a) run decently on a 386 with 387 in the first place (forget Quake...) not already run fast enough on a 386 without 387 (SimCity flys anyway on a 386-16) is Falcon 3.0.
Reply 35528 of 53137, by Mephusto
imi wrote on 2020-08-19, 11:46:
Mephusto wrote on 2020-08-19, 10:08:
Thanks for the info and its less of needing the fpu so much as wanting one 😀
I can very much understand this sentiment :3
Yeah it is mostly learning for me, but I figure I may as well put as much into it as I can 😁I am also going to try to figure how much ram I have and see what I need to get and see if I will be able to max it out. I also have to learn the cache stuff for it too. I have been looking at the info on that site you linked earlier and I have been looking at both of the 386 systems. I am super excited for these systems. Oh and I think I want to do the Compact Flash to IDE too.
Reply 35529 of 53137, by appiah4
I don't think there will ever come a day when 775 motherboards will ever be expensive.
Reply 35530 of 53137, by appiah4
dionb wrote on 2020-08-19, 09:06:
To be fair a Falcon 3.0 on a 387 wouldn't be fun times either I would think.
Unless you are going to use CAD software from a very specific window of time, 386 co processors are an absolute waste of money.
I could even debate the merits of going with a 486DX/DX2 over an SX/SX2 as well.
Reply 35531 of 53137, by Miphee
appiah4 wrote on 2020-08-19, 13:06:
Probably not, except for the deluxe versions. But I like the idea of having a huge variety of boards to choose from 25 years later without the need to buy from a limited supply. 😀
Reply 35532 of 53137, by kixs
appiah4 wrote on 2020-08-19, 13:08:
To be fair a Falcon 3.0 on a 387 wouldn't be fun times either I would think. […]
I played Falcon 3.0 on a 286/16 + 287 and as I remember it run just fine.
Reply 35533 of 53137, by Warlord
Miphee wrote on 2020-08-19, 13:22:
Depends if in 25 years anyone thinks XP, is like what people around here think windows 98 is. That is the Gen Z people but they are probably too attached totheir phones to care? who knows.
Reply 35534 of 53137, by OldCat
Indeed. There is a really short list of DOS games that use it: […]
SimCity
Falcon 3.0
MS Flight Simulator
Scorched Earth
Pub Pool
Stunt Car Racer
Quake
I am not questioning your list or knowledge, but I have a weird case: Doom. I played it in the nineties with sound in normal window (you could limit the viewable area to speed game up) on my mum's old 386DX/40 with math coprocessor (Weitek, I think, but I may be wrong after all these years) and it run as well as on my friend's 486DX2 (don't remember 50 or 66). Everybody else on 386, both SX and DX had Doom stutter, I played it to completion and enjoyed it a lot. Do you reckon this coprocessor thingy could be a reason? Or is it just my hazy memory?
Reply 35535 of 53137, by devius
OldCat wrote on 2020-08-19, 13:50:
I attribute it to hazy memory. I also remembered playing Road Rash on the Mega Drive back when it was new and in my memory it was silky smooth and had realistic graphics. I was a bit shocked when I played it again a few years ago. It runs at like 8fps...
Reply 35536 of 53137, by Miphee
Warlord wrote on 2020-08-19, 13:48:
It's completely unpredictable, there are sentimental people in every generations. Young people collect ancient coins and WW2 memorabilia too.
Reply 35537 of 53137, by devius
Same thing was said about 486 stuff in 1999. Back then most people were just giving them away or throwing them in the trash because it was useless.
Reply 35538 of 53137, by GigAHerZ
I don't know... Starting from Pentium 2, nothing really has changed. And the same way, the demand for such PCs is also a lot lower than for anything before that.
To me personally, this applies as well. I have 386, 486 and Pentium MMX, because they are fun. But Pentium 2+ are just terribly slow "today's machines".
I wouldn't bet too confidently that socket 478, 775 and such stuff ever becomes as valuable as those old machines, where new generation meant that almost everything changed.
Reply 35539 of 53137, by vetz
Highend parts of any generation will almost always have some value. For instance the Pentium 4 EE CPUs or DDR2 sticks with the best speed and lowest timings.
