HWiNFO for DOS resurrected !
Reply 520 of 950, by Mumak
Version 6.1.2 released.
Reply 521 of 950, by ALEKS
Thanks for the new version. I checked it right away. Can you put some quick release notes on the first page, as you did with the other versions (I think I said it before, I really miss the "hwinfo.his" and "hwinfo.lst" files)?
Apparently it still won't detect my I/O Interface.
Cheers,
A.
TX486DLC / 40 MHz | 32 Mb RAM | 16-bit ISA Backplane | EXCELGRAPH ET4000/W32i 2 Mb | I/O Interface | Audio Interface | PC Speaker Driver | Signal View Interface
3.5" & 5.25" FDD | 4 x 512 Mb CF | HP 82341D Interface | Intel EtherExpress 16
Reply 522 of 950, by Mumak
ALEKS wrote on 2020-08-19, 17:20:
Thanks for the new version. I checked it right away. Can you put some quick release notes on the first page, as you did with the […]
Cheers,
A.
Yeah, unfortunately I lost my interim notes for this version 🙁
All that I recall is: improved support of Trident graphics cards, IBM VGA and some CPUs.
It should also identify you IOIF-301 ISA I/O Interface in the BIOS extensions list.
Reply 523 of 950, by ALEKS
Thanks for the updates on the release notes.
Now coming back to the BIOS extensions, in my case, HWiNFO lists none, as pictured.
The attachment hwinfo-no-extensions.jpg is no longer available
In this particular case, the ROM is placed at D000-D1FF (but can vary by DIP switches if there are other cards installed). As a side note, these are EEPROMs and have the /WE signal configured as writable from DIP switches. But that wouldn't pose any issues for detection as I don't think HWiNFO also tests for writable memory area.
Here is a screenshot of memory mapping from MSD. I intentionally unloaded everything from UMA so that it will list only ROM mappings.
The attachment msd-rom-mapping.jpg is no longer available
Cheers,
A.
Reply 524 of 950, by Mumak
ALEKS wrote on 2020-08-20, 06:20:
Thanks for the updates on the release notes. Now coming back to the BIOS extensions, in my case, HWiNFO lists none, as pictured. […]
Cheers,
A.
Thanks. This is quite strange as HWiNFO scans from 0xC800 incrementaly by 0x100 and checks if there's an OROM present (starting with 0xAA55).
Then your OROM is being detected if offset 0x7 == "I/O-IF ROM".
I'm staring at the code but can't figure out why it didn't find it...
Reply 525 of 950, by ALEKS
I tried with older versions (V.5 and V.4.6.4) and both report no ROM extensions on this particular machine.
Maybe there is something wrong with the PC that I am using, that confuses HWiNFO's detection mechanisms.
Is there anything I can do (generate a report, or send you some information from BIOS or something similar) to help?
Later Edit: I checked NSSI, which I don't use that often, and it says an Unknown ROM is present at address 0xD000.
Reply 526 of 950, by Mumak
Please run the attached file and post the files it creates.
The attachment GETBIOS.zip is no longer available
Reply 527 of 950, by ALEKS
I have made a .ZIP file with the ROM images extracted with your utility.
Reply 528 of 950, by Mumak
Thanks! Finally found the bug, it's my fault. Please try the attached build if it finds it now.
The attachment HWINF612.ZIP is no longer available
Reply 529 of 950, by ALEKS
Thanks for the fix. It works correctly now!
The attachment hwinfo-detection.jpg is no longer available
One more thing though. Not that it matters most, but launching the program by using a relative path to the .EXE file, from the current directory, still throws a < Cannot open "HWiNFO.DAT" ! > fatal error.
In other words, HWiNFO resides in C:\UTILS\HWINFO. I can reproduce the bug with the following sequence:
cd utils
hwinfo\hwinfo
Even using an absolute path before the filename would throw the same error.
c:\utils\hwinfo\hwinfo.exe
Cheers,
A.
Reply 530 of 950, by Mumak
Thanks for the feedback! I will have a look at this a bit later, currently have tons of work on the Windows version.
Reply 531 of 950, by feipoa
I currently have a Dell Precision Workstation 610 motherboard on the testbed because of some other work I was doing on it to adapt Dell power supply pinouts, Adapter cable for a 24-pin DELL ATX? It is a dual slot 2 Xeon system based on the 440GX chipset. I was having some trouble getting 2 GB of SDRAM working, Problem running 2 GB of SDRAM on a Xeon dual slot 2 440GX motherboard So I decided I would use HWINFO to read SPD values from the RAM modules. My findings are as follows:
1) HWINFO is reporting the manufacturer date as being in the future (2052 week 39). I'm not sure if HWINFO is to blame or if the SPD data is false. Of course there is a third possibility, but I don't think this went back in time on a time machine, and if it did, I'd sure hope that PC100 memory isn't still being produced 30 years from now.
2) Are you able to list other SPD values in the format CL-RCD-RP-RAS which is how Windows programs usually list them, e.g. 3.0-2-2-5?
Reply 532 of 950, by darry
feipoa wrote on 2020-09-01, 01:56:
CPU-Z also reads SPD data, maybe you could compare with its results .
Reply 533 of 950, by feipoa
Unfortunately, CPU-Z didn't work on my ServerWorks HE-SL Tualatin board when I had it out.
Reply 534 of 950, by Mumak
Problem with early DIMMs is that the format used to keep the manufacturing date was not fully defined in the specification. So each vendor used a different way of encoding and one can only guess this.
The other timings should be easy to calculate - 20 ns @ 100 MHz (= 10 ns) -> 2.
Reply 535 of 950, by feipoa
Mumak wrote on 2020-09-01, 07:20:
Ahh, too bad.
Are you willing to add these values pre-calculated in conventional form? I think most users would appreciate this.
Reply 536 of 950, by Grzyb
Is it normal that under "Drive info" there's no ATAPI CD-ROM ?
I'm using HWiNFO 6.1.2, Pentium III, Intel 815E chipset, Intel 82801BA ICH2X/M - Ultra-DMA/100 IDE Controller.
Primary Master - HDD, detected correctly
Secondary Master - CD-ROM, "<Empty>"
The CD-ROM is correctly detected by BIOS, Linux, Windows, and works fine.
Reply 537 of 950, by Mumak
Grzyb wrote on 2020-11-22, 10:00:
Is it normal that under "Drive info" there's no ATAPI CD-ROM ? […]
No, that's not normal. Is it a standard IDE/ATAPI CD-ROM? Can you try to open the Drives screen a few times if it will show up?
Reply 538 of 950, by Grzyb
Mumak wrote on 2020-11-22, 10:31:
The CD-ROM is LG CRD-8522B
I tried entering "Drive info" multiple times, but it never shows up.
Reply 539 of 950, by ruthan
Grzbyb - Try Navratil system info, if it display it correctly.. it means that HW is ok and could be detected.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
