First post, by konc
Hi all,
Sometime in the past I got a Chaintech 4SLD and a thread in this forum had a link pointing to the original jumper settings guide.
102.79 KiB
Unfortunately the whole thing is a huge smudge, it's enough to do the setup once but I wanted to use the board extensively, swapping parts etc. So I got tired of it, decided to recreate it and eventually share it.
Disclaimer: If you intend to use this double check your settings from the original, typos/mistakes are a possibility and I don't want you to fry anything because of them.
150.54 KiB
Reply 1 of 2, by keropi
I will add to this thread with the info on how to add the missing PS/2 mouseport and how to install a CR2032 battery on the 4SLD5.Z1 board:
    4sld5-z1_mouse.zip
    44.85 KiB
    46 downloads
    Chaintech 4SLD5.Z1 BIOS modded for PS/2 mouse support
