First post, by konc
- l33t
Hi all,
Sometime in the past I got a Chaintech 4SLD and a thread in this forum had a link pointing to the original jumper settings guide.
Unfortunately the whole thing is a huge smudge, it's enough to do the setup once but I wanted to use the board extensively, swapping parts etc. So I got tired of it, decided to recreate it and eventually share it.
Disclaimer: If you intend to use this double check your settings from the original, typos/mistakes are a possibility and I don't want you to fry anything because of them.
