Reply 640 of 1177, by red-ray
- l33t
Camtheman wrote on 2020-09-11, 08:52:Needless to say there's quite a bit missing. Can't read the bios date among many other things.
Thank you for the report and the BIOS date is missing as SIV does not have a VXD for Windows 9x, were you to boot Windows NT then the BIOS date should be reported. In general Windows 95 does not have many of the SetupAPI routines SIV needs and with NT4 or W98 SIV would do better. The other issue is that the system has IBM MicroChannel (MCA) rather than PCI and SIV has no MCA support at all. Looking at the CPUZ report you posted neither does CPUZ.
From checking https://www.geoffchappell.com/studies/windows … story/index.htm I suspect NT4 is the last version of Windows to support MCA, is it?
