Janes IAF in Windows 10?
First post, by Muz
The game runs slow in cockpit, any fix for this?
Reply 1 of 9, by BEEN_Nath_58
How do you run the game, does it run directly or you use dgVoodoo DxWnd. I use dgVoodoo for it and it seems fine.
Reply 2 of 9, by Muz
Discrete_BOB_058 wrote on 2020-10-13, 07:20:
What files do you need for installation of dgVoodoo?
Reply 3 of 9, by BEEN_Nath_58
Muz wrote on 2020-10-13, 12:47:
Since it's old game, you will be needing D3DImm and DDraw file and also the configurator
Reply 4 of 9, by Muz
Did you run this in Windows 10?
Reply 5 of 9, by BEEN_Nath_58
Muz wrote on 2020-10-16, 12:30:
Yes on Win10
Reply 6 of 9, by Muz
The screen goes black when I included the dgVoodoo files, I can hear sound, but only black screen. My specs is Latitude 5480.
Reply 7 of 9, by BEEN_Nath_58
Muz wrote on 2020-10-16, 20:18:
The game only would work in Windowed mode at 480p
Reply 8 of 9, by Muz
How do you run it in 480p? Using DxWnd?
Edit: I have included WineD3D dll files in the game, and the game runs fine.
https://fdossena.com/?p=wined3d/index.frag
The only downside is when I press F10 for rear view key, the game pause... And have to repress to unpause the game. How to disable the F10 feature?
Reply 9 of 9, by BEEN_Nath_58
Muz wrote on 2020-10-17, 03:55:
How do you run it in 480p? Using DxWnd? […]
The game runs at 480p default. I just use dgVoodoo to run it in Windowed mode so that it doesn't get black screen. After the game starts in the plane, I can go to FS mode
