First post, by Muz
The game runs slow in cockpit, any fix for this?
How do you run the game, does it run directly or you use dgVoodoo DxWnd. I use dgVoodoo for it and it seems fine.
Discrete_BOB_058 wrote on 2020-10-13, 07:20:How do you run the game, does it run directly or you use dgVoodoo DxWnd. I use dgVoodoo for it and it seems fine.
What files do you need for installation of dgVoodoo?
Muz wrote on 2020-10-13, 12:47:Discrete_BOB_058 wrote on 2020-10-13, 07:20:How do you run the game, does it run directly or you use dgVoodoo DxWnd. I use dgVoodoo for it and it seems fine.
Since it's old game, you will be needing D3DImm and DDraw file and also the configurator
Did you run this in Windows 10?
Muz wrote on 2020-10-16, 12:30:Did you run this in Windows 10?
Yes on Win10
The screen goes black when I included the dgVoodoo files, I can hear sound, but only black screen. My specs is Latitude 5480.
Muz wrote on 2020-10-16, 20:18:The screen goes black when I included the dgVoodoo files, I can hear sound, but only black screen. My specs is Latitude 5480.
The game only would work in Windowed mode at 480p
How do you run it in 480p? Using DxWnd?
Edit: I have included WineD3D dll files in the game, and the game runs fine.
https://fdossena.com/?p=wined3d/index.frag
The only downside is when I press F10 for rear view key, the game pause... And have to repress to unpause the game. How to disable the F10 feature?
Muz wrote on 2020-10-17, 03:55:How do you run it in 480p? Using DxWnd? […]
The game runs at 480p default. I just use dgVoodoo to run it in Windowed mode so that it doesn't get black screen. After the game starts in the plane, I can go to FS mode
