First post, by AlessandroB
considering the success of the last post, and for the same reason, I now ask this question. Onboard there should be a 69000 ...
tnks
Reply 1 of 16, by The Serpent Rider
https://www.youtube.com/watch?v=xIMunG7FPKg
Reply 2 of 16, by Joseph_Joestar
You should go all in and use an ISA graphics card.
My retro stuff
Reply 3 of 16, by chinny22
That'll depend on what games
Assuming you mean a C&T 69000, and if it is it's 2MB?
Dos games should be fine
C&T 69000 is good for retrogaming?
2D windows games will also be fine, although the 2MB will limit what resolutions you can run
Basically if you want 16 bit High colour you can go as high as 800x600
If you drop down to 256 colour's you can get 1280x1024
3D accelerated games will be terrible though unless your including a adding a Voodoo1/2 for glide games.
Reply 4 of 16, by AlessandroB
chinny22 wrote on 2020-11-19, 10:54:
That'll depend on what games Assuming you mean a C&T 69000, and if it is it's 2MB? […]
i know, but my other system with c&t graphich have less powerful cpu
Reply 5 of 16, by chinny22
Not sure why you mention the CPU? That's not going to change the resolution or 3D limitations.
The CPU will only make a difference if running games using software rendering (which is your only choice with this card anyway) but that's already a significant downgrade to using a proper 3D card.
Here's someone running a S3 Trio on a P3 600, also a card with very weak 3D performance. You can expect similar (but worse) results with yours.
https://youtu.be/2LGgo4wkyr8
Reply 6 of 16, by AlessandroB
That's what I meant, my other system with P233MMX obviously the power of the cpu would allow you to play 3D games ONLY in the presence of a 3D card. The question is whether a much more powerful cpu could make up for it, perhaps choosing lower resolutions.
Reply 7 of 16, by AlessandroB
and.... it is better to have a PIII 850Mhz without a 3D card or a Pentium200Mhz with PCI 3D card???
Reply 8 of 16, by BinaryDemon
AlessandroB wrote on 2020-11-28, 09:46:
Apparently I missed the other thread - so no sure what exactly your trying to play. For Win9X gaming, most games from the Pentium 200mhz era didnt require a 3d card and have a software rendering option. I would think most games before year 2000 would play better on the PIII-850mhz + 2D until you hit the point were a GPU is required. Dos gaming might be easier on the P200 since you wouldnt have to worry about running too fast for things.
Reply 9 of 16, by AlessandroB
BinaryDemon wrote on 2020-11-28, 11:50:
ok tou hit the point. I don't have a specific game that I necessarily want to use with the P3 or the P200. Simply testing software and games (before 2000) I would not like to find that most games do not work even with a very powerful cpu like the P3. If trying the software a few very demanding games don't work is not a problem, the important thing is that the majority of 3D games work well in software render, even at low resolutions. For example I prefer quake1 in 320x200 because it reminds me more of the mode I played when it came out.
However if using the P200 + 3D card most of the time the games work better than in software mode with the P3, I will get a 3D PCI card. Moreover, the P200 only accepts 3D PCI cards and this must be taken into account.
Reply 10 of 16, by matze79
if you would say PII 300 or PIII 800.. the PII would beat the shit out of the PIII in some, if not all Cases with a 3D Card installed.
Reply 11 of 16, by AlessandroB
matze79 wrote on 2020-11-28, 13:57:
But is not a PII300 but a P200(non MMX).
Reply 12 of 16, by ODwilly
Id rather have the Pentium 1 with a 3D Rage or Voodoo or some such card than a P3 with just 2D. The Pentium 1 with 2D and lowend 3D has alot more usefulness than the P3. Although the P3 with a good 3D card or a C3 cpu and the 2D would be really handy
Reply 13 of 16, by AlessandroB
yes, but I can't understand where the meeting point between P1 + 3D card and P3 + 2D card is. Unfortunately I don't have a voodoo2 and I can't compare them. I have only your advice to know what is best
for example, Screamer2 is fast on a P200+voodoo2 or P3 850?
Reply 14 of 16, by Anonymous Coward
That resolution should be possible with only 1MB. Assuming the graphics chip can properly support 2MB, 1024x768 should be doable in 16-bit as well.
Reply 15 of 16, by AlessandroB
Anonymous Coward wrote on 2020-11-29, 05:26:
it is not abiut resolution, tge lowest can be enough
Reply 16 of 16, by hwh
I'm enjoying Rollercoaster Tycoon on a Trio at 1024x768x16 (2MB) while my replacement graphics card is shipped from Florida. Rendering is smooth in full screen. Windowed turns into a fast slideshow. I don't think it matters what the CPU is as long as it's fast enough (for this game, documentation suggests no benefit past P200).
