First post, by Dave Bursik
Hello,
I have theese 30pin SIMM modules ( each od them is 512kB - I hope ).
I tried to use them in 386 or 486 motherboards, but BIOS cannot read them. It is strange, because there is no problem with all my 1MB modules.
Any idea how or where to test them ?
Thanks,
David
Reply 1 of 13, by debs3759
Are they double sided? That poses a problem for some motherboards.
Reply 2 of 13, by Dave Bursik
No, they are not double sided.
My 1MB modules are 1 sided too - there is no problem.
David
Reply 3 of 13, by Horun
Most older 286 and 386 motherboards that have 30pin simm sockets will only work with 256k, 1Mb or 4Mb simms.
Good examples is the ASUS ISA-386C or FIC LEO 386's.
I have some 2Mb 30 pin that only work in a specific AST motherboard (and an older Apple Mac)
What motherboard are you trying to test them in ?
Reply 4 of 13, by Dave Bursik
I tested them on:
M321
M396 VR1.1
Unichip UNI-386WB 387C REV1.0
Also I have HED-988 board, but unfortunately there is possible to use only SIPP modules 🙁
Reply 5 of 13, by Grzyb
They are 256 KB + parity.
Are you sure the bank is filled up?
Memory bank = 2 x SIMM30 for 386SX, 4 x SIMM30 for 386DX/486.
Nie rzucim ziemi, skąd nasz root!
Reply 6 of 13, by Robin4
You can test these with a memory tester.. Which arent easy to get these days..
I used them myself.
Reply 7 of 13, by Dave Bursik
Grzyb wrote on 2020-11-19, 17:12:
Each module has two 256kB chip and third one for a parity. So I assume the capacity of each module is 512kB.
David
Reply 8 of 13, by maxtherabbit
Dave Bursik wrote on 2020-11-20, 16:21:
David
Each "256kb" chip is 256k x 4 bits. It takes two of them to make 256 kiloBYTES
Reply 9 of 13, by Dave Bursik
maxtherabbit wrote on 2020-11-20, 16:23:
David
Are all of them 256k x 4bit? I think just two modules are 256k x 4bit..
Reply 10 of 13, by maxtherabbit
Yes. Punch in the IC part numbers into google and see for yourself
Reply 11 of 13, by zyga64
Third IC (for parity) is 1-bit wide, which results with 9-bit SIMM.
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 12 of 13, by Caluser2000
The Dos memory testers such as the ones in Norton Utilities , checkit , Central Point PC tools and many others should be able to test them just fine if the motherboard supports them.
Reply 13 of 13, by Dave Bursik
Hello,
thanks. I checked DRAM configuration for the M321 motherboard.
DRAM CONFIGURATION
Size Bank 0 Bank 1
1MB (4) 256K x 9 NONE
2MB (4) 256K x 9 (4) 256K x 9
4MB (4) 1M x 9 NONE
5MB (4) 256K x 9 (4) 1 M x 9
8MB (4) 1M x 9 (4) 1M x 9
16MB (4) 4M x 9 NONE
20MB (4) 4M x 9 (4) 1M x 9
32MB (4) 4M x 9 (4) 4M x 9
So I think my modules should work with motherboard ... ???
Each module is 256k x 4-bit +256k x 4-bit + 1-bit wide parity chip
David
