Compaq Armada 7360DT
First post, by Dave Bursik
I have old notebook Compaq Armada 7360DT - unfortunately without AC adapter. It has a specicfic 4-pin connector.
Does anybody know pinout of this connctor? I just know parametres od the adapter 18,5V and 3,2A. Compaq part nuber should be 341809-101.
Has anybody this adapter to sell ?
Thanks a lot.
David
Reply 2 of 5, by Dave Bursik
MAZter wrote on 2020-11-24, 13:59:
Hi, thank you. I know I can buy it on ebay, but shipping is crazy 🙁
7USD for the adapter si OK, but 32UDS for the shipping...too much...
So the pinout of the connector could help me..
David
Reply 3 of 5, by aha2940
Dave Bursik wrote on 2020-12-01, 10:34:
Hi, thank you. I know I can buy it on ebay, but shipping is crazy :( 7USD for the adapter si OK, but 32UDS for the shipping... […]
David
The pinout of the adapter is on your first pic, on the line reading "Caution: for indoor use only" on the right is the drawing of the connector. It seems to say the right part of the adapter is positive, the left part is negative. To test that, you could open the laptop and see where the pins of the plug go. Negative should go to ground.
Reply 4 of 5, by Dave Bursik
aha2940 wrote on 2020-12-01, 15:27:
David
🤦 Thank you 😁
Reply 5 of 5, by Dave Bursik
I found this:
https://imgur.com/a/0ftizzH
| 1 3 |
| 2 4 |
\____/
1 - +18,5V (19V will work too)
2 -
3 - Ground
4 -
Betwen 1 and 4 connect 2,2k-ohm resistor.
