Reply 17500 of 31257, by Thermalwrong
I've been having fun today with getting my Soundblaster 2.0 knock-off to have CMS sound. It works with the same CMS GAL as described here, pinouts are all the same 😀
The first GAL16v8 I bought was a used one, which was a mistake because pin 3 on that chip didn't work, which lead to patchy / single channel CMS audio. The fresh GAL16v8D came in a couple of days ago, .jed file made and flashed onto the GAL.
After that, just remove the CMS jumper, install the chips and it works. I've only tried it in KQ1 so far, but it sounded good with really nice stereo effects.
With that, I had a good reason to test out this PCA-6134P SBC I bought last week. A cacheless AM386 SX-40 made in around '96 that takes 72-pin SIMMs for memory. It even has LBA support in the BIOS 😀 To start with when I plugged it in, it seemed to be cutting out, that that was just because I'd set the bench PSU current too low and it was detecting a brown-out and shutting down. The CMOS battery on the dallas chip block is dead but the board appears to be working otherwise.
This little PC has it all, motherboard, CPU, DC-DC PSU, IDE, floppy, parallel/serial then graphics and soundcard in this fairly tiny space of 190 x 150 x 80 mm
Reply 17501 of 31257, by Grzyb
Thermalwrong wrote on 2020-12-12, 00:49:
Looks like this card - Re: Help with Drivers for an 8-bit SB 2.0 clone?
I think I have such a card, too, together with a manual which says that CMS is not supported, so I never bothered to try...
but if it works for you, I'm going to install those chips anyway!
Reply 17502 of 31257, by UltimateElectronic
I put a socket on a mainboard that had a soldered in Dallas RTC chip. Oh and I used Windows XP on a CRT monitor from 1997.
Reply 17503 of 31257, by Thermalwrong
Grzyb wrote on 2020-12-12, 05:16:
Looks like this card - Re: Help with Drivers for an 8-bit SB 2.0 clone? I think I have such a card, too, together with a manual […]
Yeah it's that exact card 😀
The manual that I found makes mention of the Optional C/MS Wafers, and the wiring did match up with what's defined here in scorp's video. The MSI006 seems to be quite close in function to the SB 2.0's CT1336a.
Here's the .jed file that I used and is working on mine if you'd like to try it out.
Reply 17504 of 31257, by Caluser2000
Cleaned up the dot matrix printer and Amiga A600s plastics. The Amiga was very yellowed.
Reply 17505 of 31257, by SVD
Ahhhghh
So thats why it wont start...
Edit: If anyone have a picture of the area around/under the battery on a Opti-495slc board it would be very appreciated. some traces are gone.
Reply 17506 of 31257, by douglar
Recapped my first motherboard today! Well, first successful recap. I practiced on a cadaver board first. Didn't work before or after.
This board (m7ncg 400) sort of worked before, which was amazing to me because all of the 3300uf caps had nearly lifted themselves off the motherboard within a day after powering it up for the first time in years. Didn't like being woken from it's long slumber, I guess.
The attachment Photo Dec 12, 2 47 59 PM.jpg is no longer available
There is a spot for a 5th 3300uf capacitor on the motherboard that was not occupied. I see that it would block the heat sink. Any chance the board would be more better with an extra capacitor or would I kill the patient?
Reply 17507 of 31257, by evasive
SVD wrote on 2020-12-12, 19:34:
Ahhhghh
UH19 now has 10 different identified OPTi 495SLC boards to choose from. More info would be welcome I think.
https://www.ultimateretro.net/en/motherboards/?chipsetId=375
Reply 17508 of 31257, by SVD
evasive wrote on 2020-12-12, 20:09:
Ahhhghh
http://www.win3x.org/uh19/motherboard/result/?chipsetId=375
Ahh thanks, it is this http://www.win3x.org/uh19/motherboard/show/1487
Reply 17509 of 31257, by Ozzuneoj
I just cleaned up a couple of mechanical keyboards I've had laying around since spring. One is a Vendex XT-compatible in beautiful condition (with, I believe Hi-Tek switches) and the other is a Focus FK-2001 which seems to have some kind of white Alps switches.
Also had to fix a broken case tab on the Focus (it was shipped to me without sufficient packaging), which took some creativity involving a piece of metal harvested from an old floppy disk slider.
Can't wait to put them to use. 😀
Reply 17510 of 31257, by UltimateElectronic
Ozzuneoj wrote on 2020-12-12, 21:09:
Interesting, I used to have one of those FK-2001 keyboards, but it was rebranded as "Microbits". I think they might have been an Australian company.
Reply 17511 of 31257, by Dmetsys
Did some investigation work on the dead M577 / Amptron PM-9900A. Turns it has broken traces all over the place, especially in the FSB jumper area. Who ever had this board didn't treat it that well. Well, now it becomes wall art. 😜
NF7-S 2.0 | 2500+ @ 3200+ | 9700 Pro | Audigy2 ZS
CUV4X 1.03 | PIII-933 | MX400 | Live! Value 4670
P5A-B | K6-2 450 | TNT2 | AWE64 Value
4DPS | Am5x86-P75 | S3 Vision864 | SB16 CT2290
Reply 17512 of 31257, by Horun
I worked on a Amptron PM9100A over the last few days, was dead and now it works. Had broken+shorting SIMM socket plus some other minor stuff.
Only thing left to do is flash the BIOS to newest version and find proper Serial/LPT back plate.
Did find a Video back plate that works with the onboard header so do not need to use a PCI card but probably will when/if I build a system out of it.
Reply 17513 of 31257, by bjwil1991
Swapped the power boards between the AMS and Austin laptops as the one in the Austin shorted and caused the laptop to turn on when plugged in. My initial plans are to remove the battery terminals and reflow solder on the one IC that has a bit of corrosion on it.
Reply 17514 of 31257, by RetroLizard
Would a Voodoo 3 3000 go well with a Geforce 6200 AGP card?
Reply 17519 of 31257, by creepingnet
Actually, as of the moment of writing this, I'm posting this while doing some quasi-unofficial DOScember-ish stuff for my YouTube channel. So me writing this post will turn up in the video.
~The Creeping Network~
