Reply 40 of 53, by 0x1F9F1
WhiteBear wrote on 2021-01-07, 15:26:0x1F9F1 wrote on 2021-01-05, 20:00:Discrete_BOB_058 wrote on 2021-01-05, 17:17:Thanks for the update.
Btw could you share what was the problem which caused the music to stop 😀.Bugs 😀
By the way, is there a possibility for the original OpenMM1 to have fixed menu audio too? I really like the original OpenMM1 and I use it for trying different settings with dgvoodoo. If it can be fixed then that would be really amazing. I would like to try both OpenMM1 and Open1560. Thanks a lot for your efforts. I hope that the audio issue can be fixed for MM2 too.
I have no plans to update OpenMM1 anymore. If you really still want to use DDRAW, you can build Open1560 from source and disable OpenGL.
As for MM2, my changes may get copied to mm2hook since the audio code is almost identical for both games.
