Reply 60 of 114, by PeterLI
Reply 61 of 114, by Lennart
I've made a schematic for the 16-bit ISA version of this card, which I've attached to this post. I hope it's useful to someone! 😀 The schematic is fairly complete, apart from some decoupling capacitors which I left out. Note that the 8-bit ISA version is very similar, except that it doesn't allow IRQ 10/11/12 to be selected and it has a separate ROM chip for the program code, whereas the 16-bit ISA version has an on-chip ROM embedded within the microcontroller.
Reply 62 of 114, by carlostex
Does anyone know if the breakout cable for the Music Quest card will also work with a MIDIMAN MM-401?
Reply 63 of 114, by Stojke
It worked on MIDI Land DX-401, check the PCB traces.
Reply 64 of 114, by carlostex
Can't check right now, card is in Portugal i'm on the UK.
Reply 65 of 114, by Marmes
PCB is doable 😀
Reply 66 of 114, by keropi
^ indeed 😉
main problem atm is PAL code and verification of RP1 and RP2 resistor networks.
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 67 of 114, by Marmes
now all we need is tha pal code 😜 RP is easy to see.
Reply 68 of 114, by mvmiller12
So. . . is it possible to purchase a pair of updated v010 ROMs to replace the v004 ROMs I have on my pair of these? If so, it would really resolve a lot of kludgy workarounds that I have to keep running on my 486DX4/100.
Reply 69 of 114, by keropi
purchase? music quest doesn't even exist AFAIK...
getting an eprom with the new fw is another matter , pm me
Reply 70 of 114, by vetz
bjt wrote:
Does WC work with the Music Quest card if SoftMPU is loaded?
Browsed through this whole thread and internet to find answer to this. Well, I got my own Music Quest MQX-32 and the answer is that SoftMPU fixes the crash 😀
The MQX-32 has the same crash problem in WC as the PC MIDI card with rom 004.
Reply 71 of 114, by keropi
allright gents, here are the new developments on the this little card...
I decided to hack-read the PAL on U5 so we can get the code. The PAL died ( 🤣 ) and no code was recovered ( 🤣 ). So I've been working with Marmes (actually Marmes writes GAL code and I test it) to make a replacement chip.
I do have another identical MPU and the good PAL works on the board with the dead PAL, so the only thing lost is 1x read protected PAL.
TIA! 😎
Reply 72 of 114, by shock__
Last 2 numbers usually indicate the maximum frequency in Zilog (co-)processors. So the datasheet you have is very likely to be the correct one.
The probably changed the Z8 -> Z08 to avoid confusion later on when the Z80 became more widespread.
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 73 of 114, by nsputnik
I am wondering if anyone has the sequencer that was included with Music Quest MIDI Card called Easy-8. I checked the disk files (the drivers) linked to by the OP but did not see them.
Reply 74 of 114, by keropi
nsputnik wrote on 2020-07-29, 16:02:
well it was not in my boxed card, all I had was a disk with the driver/diagnostics that I uploaded...
Reply 75 of 114, by matze79
Anyway, Happy Birthday Keropi ! 😀
Reply 76 of 114, by keropi
matze79 wrote on 2020-07-30, 16:29:
hehe thanks!!!!!!
Reply 77 of 114, by dysamoria
Hello; this is my first post here...
I resurrected my Tandy 1000 TL/2 and 2500 XL/2 recently. Had to temporarily install the 3.5" FDD from my Akai S6000 into the 2500 XL/2, and I suspect either the power supply or the hard drive are dying (hard drive doesn't spin up right away, but the power doesn't come on for a second after switched, so...). For now, it works, and I'm messing around with old games. I just discovered what happens in Wing Commander 1, when trying to run it with an MT-32 through a Music Quest PC Music Card with the 004 firmware. Yup, it's freezing at the fireworks like everyone else described.
When I was a kid, I wanted the MT-32, but there was no way I was getting it (allowance didn't cover $650 worth of game music hardware, even though I absolutely tried to justify it to my parents as a music-making tool). I used my Casio MT-540 with it, and a couple games even support it, but, come on, it's no MT-32! It's kind of annoying that, after all these years, I now have two second-hand Roland MT-32 units to use with that supposedly "100% MPU-401 compatible" MIDI card I bought as a 14-year-old, but I still can't play most of the games I want to play because they use "Intelligent Mode" and the card firmware is buggy. Sigh.
Luckily, my card's firmware chip is already in a socket (let me know if you want a picture). What would be the best way to get the working firmware?
Reply 78 of 114, by keropi
dysamoria wrote on 2021-01-15, 00:24:
Welcome aboard!
Since your card already has a ROM socket upgrading it is very easy, just burn a new 27C64 (or 27C128/256/512) with the 010 firmware and put that into the socket, nothing else is needed!
Reply 79 of 114, by dysamoria
keropi wrote on 2021-01-15, 06:32:
Welcome aboard!
"Just"... ha ha... 😁 I don't have an EEPROM writer or the ROM image.
