First post, by Sphere478
I have a multi booting k6 3+ system that has a pci usb 3.0 card in it. The drivers say it's a "Renesas usb 3.0" but sold as "Startech 4 Port PCI USB 3.0 Card" it works fine in windows 7 but I was wondering if I could get it working on ME as well?
has anyone gotten something like this to work in 98/me if even only at usb2.0 speeds
    11.44 KiB
Sphere's PCB projects.
Reply 1 of 20, by Warlord
short answer is no long answer is maybe in usb 2.0 mode, but probably not on that controller thats if NUSB drivers work. Big If there. Whats the point. A k6 is barely fast enough to even work with usb 1.1 Find a NEC based usb 2.0 controller with internal headers and be happy.
Reply 2 of 20, by candle_86
You'd honestly be lucky to get USB3 working on XP, by 2011 when USB3 was finalized no one was writting Windows 98 drivers, you could make them yourself if you knew how to write drivers but outside of that or paying someone to write a custom driver (I'm going to assume sevral thousand dollars) the anwser is no
Reply 3 of 20, by Jo22
I second that. I had had got an early USB 3.0 PCIe card with a NEC chip.
The drivers made by NEC (later, Renesas) worked fine on XP SP2.
Reply 4 of 20, by DosFreak
I use my USB3 (Fresco) card in XP+. On the same box I just use the USB2 ports on the motherboard for <XP. Of course with this motherboard I have the luxury of tons of USB.
USB3 on PCI would be extremely bottlenecked doubt there would be a point to it. On those old machines firewire is best if comparing USB2 vs firewire then firewire is less cpu and faster.
No idea how esata would perform on an old machine if there is a PCI card for it.
Make your games work offline
Reply 5 of 20, by Sphere478
DosFreak wrote on 2021-02-13, 14:26:
Usb 3 at 100mb/sec is a lot faster than usb2 at 12 mb/sec which are about the speeds I’m getting
I have nothing that uses firewire. And if I got something that did use it I could use it in none of my other computers
I think I will leave the usb3 in there for win7 and just use the 1.1 ports in ME. Thanks guys.
Reply 6 of 20, by weedeewee
Hey Sphere478,
Could you take the card out, take a picture of the backside, and post it here.
It seems like there's a chip on the backside, probably the PCI-PCIe bridge chip and I'm wondering which brand/model/id it is.
Do not ask Why !
Reply 7 of 20, by Sphere478
weedeewee wrote on 2021-02-13, 19:02:
Hey Sphere478,
red one
Reply 8 of 20, by weedeewee
Sphere478 wrote on 2021-02-14, 14:55:
red one
cheers, that matches exactly with the chip on a photo I found online of that same card. 😀
Do not ask Why !
Reply 9 of 20, by weedeewee
Sphere478, Could you test them, to see if they're working, in a Asus P5A or similar SS7 mainboard with ALI chipset ?
Do not ask Why !
Reply 10 of 20, by Sphere478
weedeewee wrote on 2021-02-14, 16:30:
It probably would. Only board that has given me trouble was a lga 1155 msi board it seems to work well in most boards
I only have 430yx/hx socket 7 boards
Reply 11 of 20, by weedeewee
Sphere478 wrote on 2021-02-14, 17:30:
I tested one pci-pcie bridge on an p5a and it didn't get detected. Haven't tested it yet on any 430?x boards yet.
Do not ask Why !
Reply 12 of 20, by Doornkaat
weedeewee wrote on 2021-02-14, 17:43:
To my knowledge +3.3V isn't present on the P5A PCI slots. Could it be the bridge needs that and you have to hack your board to supply the voltage?
Reply 13 of 20, by weedeewee
Doornkaat wrote on 2021-02-15, 13:17:
Could it be that simple ? I'll test it when I get the chance. Thanks !
edit: I'm gonna say you're right without testing it. I've looked at the bridge and ... All the 5V lines are connected to each other and a few caps, though nothing visible goes to any chip that might be a regulator.
So I took out the multimeter and measured around and... aside from the 5V lines in the back being connected together, and the 5V lines on the front being connected together with some caps. They aren't connected to anything else. So yep, this board needs a 3V3 line on the pci bus to function.
Do not ask Why !
Reply 14 of 20, by Sphere478
did you have a card installed in it? i put a m.2 in one of those bridges and it seemed alright if you had a OS that supported m.2
Reply 15 of 20, by weedeewee
Sphere478 wrote on 2021-02-16, 01:08:
Yes, I had a card in it, and tried several slots, and the card worked on a PIII board so I know it works, and I tested it in an older mainboard recently and that also works.
I haven't had the chance to check the P5A 3V3 line on the pci bus yet, but if that isn't present like doornkaat said, then the card I have won't work since it wouldn't be powered.
Do not ask Why !
Reply 16 of 20, by weedeewee
Confirmed, Asus P5A has no 3v3 on the PCI slots.
Do not ask Why !
Reply 17 of 20, by Sphere478
weedeewee wrote on 2021-02-18, 18:19:
you could try and find one of those 3v converter cards or make one
Re: Dual CPU Socket 5/7 Boards
Reply 18 of 20, by weedeewee
Sphere478 wrote on 2021-02-18, 22:49:
Ain't noone got time for that 😁
I'll just think about adding a 3V3 regulator on the card.
Do not ask Why !
Reply 19 of 20, by Sphere478
weedeewee wrote on 2021-02-18, 23:35:
would back feed to the other cards also so size it big
