First post, by SETBLASTER
hi guys. im looking for drivers+manual+ latest bios update for this socket7 motherboard made by the well known DFI
letters on the board are:
P5BV3+/E revision.C
does anyone got this board that could share info and files?
Reply 2 of 9, by SETBLASTER
the problem with those sites is that the "/E rev.C" variant has no info about. and i think thry might have different bios !
Reply 3 of 9, by PC Hoarder Patrol
The attachment P5BV3+_e. Rev. C+ System Board.pdf is no longer available
Reply 4 of 9, by Repo Man11
Recommended for Win98 and Via MVP3 chipsets: Re: DFI K6XV3+/66 (ATX SS7 board) unstable with GeForce cards - BIOS bug
Reply 5 of 9, by Horun
Great job guys ! I did find the rev C manual but am late to the party as usual.
Here is the last CPU support update I could find (from 2000).
Have not found any BIOS files that are usable yet...
Reply 7 of 9, by SETBLASTER
PC Hoarder Patrol wrote on 2021-03-06, 04:16:
This post on Win3x.Org (presumably the same @douglar as here) […]
http://www.win3x.org/win3board/viewtopic.php?f=95&t=26958
for a Rev B board, has a link to possible BIOSes here
https://driverscollection.com/?H=P5BV3%2B%20/ … &By=DFI&dpage=2
awesome!!! thanks, there is a bios for C that says
"Support AMD K6-2 500/­550 CPU." that would match the cpu compatibility chart image that was shared
too bad they don't support k6-2+
kind of weird because i was given this board with a k6-2+ 450mhz installed, i just never powered it on
Reply 8 of 9, by SETBLASTER
does anyone know what is the difference with the /e version and the "non /e" version of the motherboard. DFi released like 3 revisions for each.
and its possible that bios will not work between the /E and Non /E
to make the things worse i think there are modded bios for the "non /E" that support k6 plus processors.
Reply 9 of 9, by adalbert
SETBLASTER asked me on PM as I have been using this board several years ago (Super 7 P5Bv3+/e (MVP) - problem with Nvidia graphics (AGP and PCI)),
so I can attach some files
file.php?id=20051&mode=view
- 61 page long manual in color
- various BIOS versions (zipped in one file, you need to figure which ones are good...)
- VIA 4in1429v(a) driver
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
