Heap Allocation Failure
First post, by NoLander
I get a heap allocation failure (reason code: 2) when trying to run theme hospital on startup. This only happens if sound has been set by setsound.bat, which i might add is the only way to set the sound. It Works without the sound set up to anything. Can't figure out y. I haven't the slightest clue what the error message means, can anyone help?
Reply 1 of 1, by eL_PuSHeR
It sounds memory related. Try playing with memory options (XMS, EMS). Also, try executing LOADFIX before running the game.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
