First post, by NoLander
NoLander
Offline
I get a heap allocation failure (reason code: 2) when trying to run theme hospital on startup. This only happens if sound has been set by setsound.bat, which i might add is the only way to set the sound. It Works without the sound set up to anything. Can't figure out y. I haven't the slightest clue what the error message means, can anyone help?
