First post, by kalm_traveler
- Member
Hi guys, I finally have time to get back to finishing this project and will be settling on the TUSL2-C. I thought that my first one was defective because the rear USB ports were not working but after fiddling with the power jumper they actually are just fine.
I ended up buying a second TUSL2-C which helped prod me down the troubleshooting path further to figure that USB situation out, and this second one doesn't have the audio bits (first one has the built in audio components) as well as has a working PLED.
With the first one I bought, there is visibly a small SMD resistor that had been ripped off above the front panel connector which seems to be causing the PLED to not work. The resistor next to it is also nearly torn off but comparing this board to the other one both resistors say 221 which I believe means they are 221 mOhms?
I'm looking at Digikey but I'm not sure how to narrow down my search beyond surface mount resistors and 221 mOhms to make sure I'm buying the correct part to fix that first board before I sell it.
Can someone please teach me how to figure this out?
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:iRyzen 9 9950X3D, 64gb DDR5-6000, RTX 4090 FE | 2019 Razer Blade Pro
