First post, by kalm_traveler
Hi guys, I finally have time to get back to finishing this project and will be settling on the TUSL2-C. I thought that my first one was defective because the rear USB ports were not working but after fiddling with the power jumper they actually are just fine.
I ended up buying a second TUSL2-C which helped prod me down the troubleshooting path further to figure that USB situation out, and this second one doesn't have the audio bits (first one has the built in audio components) as well as has a working PLED.
With the first one I bought, there is visibly a small SMD resistor that had been ripped off above the front panel connector which seems to be causing the PLED to not work. The resistor next to it is also nearly torn off but comparing this board to the other one both resistors say 221 which I believe means they are 221 mOhms?
I'm looking at Digikey but I'm not sure how to narrow down my search beyond surface mount resistors and 221 mOhms to make sure I'm buying the correct part to fix that first board before I sell it.
Can someone please teach me how to figure this out?
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:i9 13900ks, 64gb DDR5-6000, RTX 4090 FE | 2019 Razer Blade Pro
Reply 1 of 5, by snufkin
221 is 220 ohms. First two digits are the most significant digits, the last digit is how many zeros.
[Oh, and I'd guess they are 0805 package size, about 2mm long?]
Reply 2 of 5, by flupke11
I've taken a picture of my board:
The attachment TUSL2C.jpg is no longer available
TUSL2C - revision 1.04
Reply 3 of 5, by kalm_traveler
snufkin wrote on 2021-04-24, 21:32:
ahh ok thank you, I didn't know how to identify these super tiny SMD resistors 😀
yes about 2mm long, thank you so much. On Digikey, if I pick 220 Ohms and that 0805 package it doesn't have any so I guess I'll have to find a new parts vendor.
Reply 4 of 5, by snufkin
They should have loads. Are you looking under 'Chip Resistor - Surface Mount'?
Just had a quick look, I can see about 300 options on Digikey. Biggest problem will probably be minimum order quantities.
[Ah, found one: https://www.digikey.com/en/products/detail/pa … 6GEYJ221V/89706 ]
[I should also have said, don't worry about not knowing the markings, definitely worth asking about as it's not always clear. E.g., something marked 220 is actually 22 ohms, because it's 22 and then zero zeroes. Here's a page I just found on Google: https://www.hobby-hour.com/electronics/smdcalc.php ]
Reply 5 of 5, by kalm_traveler
snufkin wrote on 2021-04-24, 22:34:
They should have loads. Are you looking under 'Chip Resistor - Surface Mount'? […]
oh crazy and thanks again! I'm not sure what I was doing on the search page but I couldn't find anything. Huge thanks again for the info link!
