3Com EISA and 3c5x9cfg
First post, by mt777
I didn't play so much with EISA systems and have question about eisa 3com adapter.
When I run 3c5x9cfg then can't find the card 3c579-TP.
Is card defective or some kind of EISA configuration is needed?
Reply 1 of 4, by Grzyb
Yes, you need to run the motherboard-specific EISA Configuration Utility.
It's supposed to detect the new card, and ask for the 3Com diskette with the appropriate .CFG file, eg. !TCM5092.CFG
Nie rzucim ziemi, skąd nasz root!
Reply 2 of 4, by mt777
Yep, that works.
How modify DS1225Y to cr2032 mod? Gnd-> Gnd, "+" -> 4148 diode -> VCC?
Reply 3 of 4, by weedeewee
mt777 wrote on 2021-05-04, 21:03:
Yep, that works.
this talks about modding a ds1225
http://worldphaco.com/uploads/TEKTRONIX_2465b … _THE_DS1225.pdf
Do not ask Why !
Reply 4 of 4, by mt777
great with internal diagram 😀
