3Com EISA and 3c5x9cfg
First post, by mt777
I didn't play so much with EISA systems and have question about eisa 3com adapter.
When I run 3c5x9cfg then can't find the card 3c579-TP.
Is card defective or some kind of EISA configuration is needed?
Reply 1 of 4, by Grzyb
Yes, you need to run the motherboard-specific EISA Configuration Utility.
It's supposed to detect the new card, and ask for the 3Com diskette with the appropriate .CFG file, eg. !TCM5092.CFG
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 2 of 4, by mt777
Yep, that works.
How modify DS1225Y to cr2032 mod? Gnd-> Gnd, "+" -> 4148 diode -> VCC?
Reply 3 of 4, by weedeewee
mt777 wrote on 2021-05-04, 21:03:
Yep, that works.
this talks about modding a ds1225
http://worldphaco.com/uploads/TEKTRONIX_2465b … _THE_DS1225.pdf
Do not ask Why !
Reply 4 of 4, by mt777
great with internal diagram 😀
