DOSBox, DPMI & Quake
Reply 20 of 35, by wd
Rank DOSBox Author
DOSBox Author
Did sound work before you changed the configuration?
Does sound work at all? Try some other games to test.
Reply 21 of 35, by rautamiekka
Sounds worked before, but were streched. I can't hear any sound at all. I only have this game but hmm ... I try Duke Nukem 3D ... (I manage to get it work on my xp pro but it lags and hear no sounds.)
Reply 22 of 35, by rautamiekka
Duke Nukem 3D works, but if music is enabled, it isn't running smoothly. I hear sounds. So there's something with Quake ...
Reply 23 of 35, by wd
Rank DOSBox Author
DOSBox Author
Well be sure you're using clean 0.65 release with the default dosbox.conf,
and ONLY change the core and cycles setting. Duke3d should run then
if the graphics mode is set to 320x200 and sound is correctly set up
in the duke setup (sb16 a220 irq=7 dma=1).
Reply 24 of 35, by rautamiekka
OK, I reinstall DOSbox and change those things only; I modified many sound settings from the conf ...
Reply 25 of 35, by rautamiekka
Duke3D works perfectly, unlike Quake's sounds: none at all
Reply 26 of 35, by rautamiekka
Alright ! Now works that I installed it from DOSbox
Reply 27 of 35, by Qbix
Rank DOSBox Author
DOSBox Author
gravis ultrasound. that doesn't sound right
at my place it states:
using dma channel 5
version 4 sb startup
sound sampling rate 11025
Water flows down the stream
Reply 28 of 35, by rautamiekka
Yes, I receive that same now. Thanks people 😀 The random lag can't be fixed, I guess, but it won't ruin my game sessions heh.
Reply 29 of 35, by rautamiekka
what the ... After I installed 1.06 patch, sounds are gone ! 😳
Reply 30 of 35, by kekko
set gus=false in dosbox.conf
Reply 31 of 35, by rautamiekka
Alright ... hope this thing works without breaking again.
Reply 32 of 35, by leileilol
Try disabling GUS support in the dosbox.conf. I've had that problem too. It should fall back to Sound Blaster, which will work
Debian's fucked
Reply 33 of 35, by rautamiekka
What happens if I disable all others than MIDI and SoundBlaster ?
Reply 34 of 35, by wd
Rank DOSBox Author
DOSBox Author
Nothing really magic, they're just not enabled then. Don't see any
reason to disable the other sound devices though.
Reply 35 of 35, by rautamiekka
Understood
