Leak of Windows 11
Reply 140 of 316, by dr_st
keenmaster486 wrote on 2021-06-20, 06:23:
This was good. Nobody ever complained about it. It existed for many years and everyone was used to it and knew exactly how to navigate it.
I think your "everyone" does not include people who may only have started using the computer in the last 10 years, and are not "power users". I bet most of them have no clue about the old Control Panel, and they are an ever growing user base.
Reply 141 of 316, by cyclone3d
dr_st wrote on 2021-06-20, 07:04:
I say leave the old control panel in place for those who actually need it and use the cut-down settings app for the normal users as they are the people who would tend to royally screw stuff up if they went mucking around in the Control Panel.
Those types of users are better off not having access to those types of settings.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 142 of 316, by xcomcmdr
Settings is confusing, takes way more clicks than the Control Panel, displays way less information for the same window size, and has to go.
I want my sanity back.
Reply 143 of 316, by dr_st
cyclone3d wrote on 2021-06-20, 08:08:
That's how it's been so far. If they are actually about to change it, I guess it can only mean they have decided that maintaining dual facilities is too much work...
Reply 144 of 316, by Azarien
rmay635703 wrote on 2021-06-16, 20:50:
Should have called it Windows 9
Or IX
Fill in the continuity
Ah, the Glock numbering system: no one can make any sense of it.
Reply 145 of 316, by robertmo
i like numbering system used in xbox 😉
Reply 146 of 316, by VileR
xcomcmdr wrote on 2021-06-20, 08:25:
When your average 80x25 text mode DOS program is better at using screen real-estate than a modern UI, that modern UI is due for some rethinking. 😉
Reply 147 of 316, by BEEN_Nath_58
Microsoft should remodel Control Panel, not replace it with Settings.
Reply 148 of 316, by ZellSF
xcomcmdr wrote on 2021-06-19, 14:52:
What ? First, that's a bit rude. Secondly, it doesn't counter my point. Seriously, what kind of answer is that ? […]
ZellSF wrote on 2021-06-19, 14:35:
xcomcmdr wrote on 2021-06-19, 06:58:
I encountered it. What a bullshit tactic. (I'm on Windows insider preview)
Insider previews is volunteering for bullshit. It's meant for testing, not general usage.
What ?
I'm not countering any point. I'm sure you got them on a Windows Insider build. You just sounded like you were surprised about it, and you shouldn't be because that's what Insider builds are, you're forced to sign in to even download them.
xcomcmdr wrote on 2021-06-19, 15:24:
Also, "It works on my system" is never an answer.
Sure it is, depending on the question. "This is a problem on all Windows 10 computers" is easily refuted by "It isn't on mine".
"It works on my system" is also a perfectly valid thing to note to figure out in what kind of systems it does not work. What I wrote wasn't meant to be an answer, but that something other than the build version was the problem.
dr_st wrote on 2021-06-19, 15:05:
And Googling for those terms just gives me results on how to easily disable it. Getting it on a monthly basis despite attempts to disable it doesn't seem normal enough for it to be one of the top Google results. It's a bug with your setup, not normal behaviour.
Yes, but it seems the bug is not as rare as you would think, as many of those guides that say how to disable it have comments under them with multiple people complaining it did not work for them.
Eh if it was really common, there would be much more comments and/or suggested fixes.
Discrete_BOB_058 wrote on 2021-06-21, 13:36:
Settings is their remodel of Control Panel. Their 8 year remodelling project that it looks like they're not intending to finish with Windows 11.
Reply 149 of 316, by Bruninho
ZellSF wrote on 2021-06-21, 22:23:
I have the same opinion. They will never finish it.
It’s curious: Apple despises legacy software and screws you up with updates, planned obsolescence, while Microsoft doesn’t seem to be interested in ditching legacy software at all and screws you up with automatic updates that breaks the whole thing and modern versions of their legacy software whose intuitive usage is worse than the legacy ones.
Kinda ironic, isn’t it?
JOBS, Steve.
Reply 150 of 316, by darry
I may be wrong, but I don't think they can actually finish the job for now, if that means eliminating the Control Panel completely . AFAICR, there are legacy compatibility concerns that would prevent completely yanking out Control Panel functionality .
What I hope they might eventually succeed in doing is making the Settings app have all the functionality of the Control Panel without it having to rely on Control Panel components . And, if we are very lucky, maybe the Settings app will stop looking like a mish-mash of of ill fitting components where finding what you are looking for is practically impossible without having to rely on the search option .
Reply 151 of 316, by Intel486dx33
Wallpaper looks “Girl-ish”. Like wedding wallpaper.
And some of the sounds are the same as from Win-NT 4.0 from 1995 ?….
Links:
Wallpaper:
https://www.theverge.com/2021/6/16/22536375/m … fault-wallpaper
Sounds:
https://youtu.be/kbu864tJhk8
I benchmarked MS-Windows-10 on my 2012 MacBook Pro with dual core i5 and actually MS-Windows performs better on the Mac
Than OSX in the beginning but Apple has made improvement to its OS and now they benchmark about the same.
But OSX is lighter and more efficient today. MS-Windows 10 has become BLOATWARE with to many updates.
Reply 152 of 316, by cyclone3d
Intel486dx33 wrote on 2021-06-22, 01:38:
Wallpaper looks “Girl-ish”. Like wedding wallpaper. And some of the sounds are the same as from Win-NT 4.0 from 1995 ?…. […]
Links:
Wallpaper:
Sounds:
BLOATWARE with too many updates????? R U serious? Just run disk cleanup to get rid of the old not needed files.
The updates are there to fix issues. They don't just push out "updates" to add bloat. Plus they got rid of the old Edge browser. The new Chromium one is way better.
IE will also be going away at some point which will reduce "bloat" as you call it.
YMF7x4 Guide
Reply 153 of 316, by BEEN_Nath_58
Surely not the remodel I wanted. Should have been centered more around what it is and not replace everything.
Reply 154 of 316, by Intel486dx33
cyclone3d wrote on 2021-06-22, 02:33:
BLOATWARE with too many updates????? R U serious? Just run disk cleanup to get rid of the old not needed files. […]
Links:
Wallpaper:
Sounds:
Yes, On the Intel Mac OSX loads quickly were MS-Windows 10 takes longer to start up and performs to many update tasks at startup.
It takes Win-10 about 3 to 4 minutes to settle down to idle speed of 1% CPU utilization were OSX gets down to 1% CPU utilization in just one minute.
Reply 155 of 316, by WDStudios
This was good. Nobody ever complained about it. It existed for many years and everyone was used to it and knew exactly how to na […]
file.php?id=112859
Before the Dark Times. Before the Empire.
Since people like posting system specs:
LGA 2011
Core i7 Sandy Bridge @ 3.6 ghz
4 GB of RAM in quad-channel
Geforce GTX 780
1600 x 1200 monitor
Dual-booting WinXP Integral Edition and Win7 Pro 64-bit
XP compatibility is the hill that I will die on.
Reply 156 of 316, by cyclone3d
Intel486dx33 wrote on 2021-06-22, 04:22:
Links:
Wallpaper:
Sounds:
Hmmm... Let me restart my computer and see how long it takes to settle down.
Note: I am not using fast boot or anything like that.
Are you sure your OSX machine isn't doing some sort of fast boot, hibernation or sleep mode.
How long does it take to fully boot IF it is a real cold boot (none of the above used)?
I just did a test with my current Win10 machine and it settled down in about 1 minute and that was with a bunch of stuff auto loading. Would have been more like 30 seconds or less if I didn't have any programs auto loading on login.
YMF7x4 Guide
Reply 157 of 316, by Bruninho
file.php?id=112859
Those were the days. I would totally defend Windows 98 at that time as well as OS9. The world was a better place.
Now we have a monster with terrible UI/UX (Windows 10/11) while Apples UI/UX is still great, fast and easy to use, but under the hood is starting to look a lot more like windows with their updates. Every time I update my Mac is about half an hour to install and reboot. But hey, I can do it manually and disable the automatic updates, so I do that when I have dinner and I just keep it running and updating while I eat. Not to mention the planned obsolescence of their old Macs. Hence why I have this avatar - “Choose wisely”.
Windows 10 just chooses to do so in the worst possible moment it wants, doesn’t give a f**k if I am playing a competitive online race in a wet track and within five laps to the end in P2, nearly catching up the leader, lapping three seconds faster than him on fresh new intermediate tyres, and then DANG it just rebooted and started to auto update itself. Imagine my anger when I missed what could have been my first ever race win.
JOBS, Steve.
Reply 158 of 316, by 65C02
Yeah 3-4 minutes for the CPU to settle down isn't normal. It shouldn't update at every startup.
On my computer the CPU usage settles down to 0% in 30-40 seconds with fast start disabled.
Reply 159 of 316, by robertmo
Bruninho wrote on 2021-06-22, 05:33:
that's why i suggest whenever you want to do something important go to windows updates and check if there is anything to install, same with antivir, browser, java etc 😉
anyway i suggest doing it everytime you start your pc as it is really no fun doing just anything when windows is updating in the background without your knowledge.
I guess they could make a popup to inform you that it is updating and you may experience some delays in your work and estimated time to finish
instead it doesn't inform you and just slows the process down so it just takes way longer to update than it normally should
