First post, by BEEN_Nath_58
- l33t
As we know a version of Windows 11 has been leaked. For all the tech gurus, I believe you have visited the core elements of the OS. I like the new UI design elements with the Start button in the center and also the backward compatibility hasn't been cut much(haven't checked 16-bit emulation). The installation screen has been changed to make it more "friendly" and it now doesn't ask for MS account login anymore 😀. As far as drivers go by, the VMware drivers have worked for it(probably Windows 10 ones installed). How do you see the new OS and what are the positives and negatives you find here?
