2mg wrote on 2021-07-17, 19:49:
Got an ATI Rage 128 on the way, found some for cheap. Possibly a TNT2 too. Is m64 version much worse from a normal TNT2?
Yes the M64 is severely crippled but any TNT2 will hold back performance of a 700Mhz PC.  If its TNT2 Vs Rage I'd stick with the Rage.
But wasn't a "real" internal speaker capable of more than 1bit sound? If connected to a soundcard or something?
Unlike the piezo  a "real" internal speaker is a true analogue device so in theory able to produce more sound, but the reality is we are talking about early days when every byte counted so the sound code was rarely anything advanced.
Not saying the piezo is as good as a speaker its not, but how many PC speaker only games do you actually want to play? Street Rod is my main game and it's pretty bad on both speaker and piezo 😜
PS: Is the -5v: -0.01 in BIOS an issue for anything like ISA?
Here is a list of cards that require -5v, its a small list and nothing you have been looking at
ISA Cards & Devices Requiring -5V
As for your soundcard list I've broken them down to 3 groups as the ESS ones are basically the same in real world usage, If going ESS go with best price.
All 3 are really good and the negitives aren't really that bad for example.
Not many games had 16 bit sound anyway and the ones that did may indeed support the non creative option, it's just not guaranteed.
People hate Creatives CQM, others don't really mind. I fall into the 2nd category.
Sound Blaster CT4170 Vibra 16XV
+ Full SB16 compatibility
- Has CQM not OPL
- Games that only support SB Pro will be mono only
YMF719E-S OPL
+ True OPL
+ Full SB Pro compatibility
- Game requires WSS support for 16 bit sound
ESS1869 (ES1869FC)
ESS AudioDrive ES1869FC
ESS AudioDrive ES1869FC 3D ESFM OPL3 (there's two of these)
ESS AudioDrive ES1868F ESFM OPL3
COMPAQ ESS AudioDrive ES1868F
Compaq PremierSound ESS AudioDrive 1869F
Compaq Premier Sound ESS AudioDrive ES1869F
ESS AudioDrive ES1688F / ES968F
ESS AudioDrive ES1868F BINAURA 3D OPL3
All these cards are basically the same (either a 1868 or slightly revised 1869)
+ Not a true OPL chip but highly regarded clone
+ Full SB Pro support
- Game Requires AudioDrive support for 16 bit
And yes I'd recommend a SBLive for Windows 9x
The ISA cards will work in 9x but by PCI card standards the snr rating is crap and you miss out on things like EAX.
I'd say ISA cards in 9x are about the same quality  as onboard sound on laptops. It does the job but it isn't great.
2mg wrote on 2021-07-19, 10:40:
Since this MBO can fit 66/100/133 CPU, do I need to place a CPU with FSB 133 if I use PC-133 RAM? Basically, does 500E benefit from PC-133 over PC-100?
You don't need to match CPU and RAM. I put 133 ram in all my builds even though all of my CPU's are only 100 Mhz. My thinking is maybe the faster ram makes a difference? probably not but the price difference is next to nothing so who cares!
