My Saturday. Old and new.
Non-retro got my 39" monitor in place mostly properly, retro got hold of a 2000 or so NEC Multisync 1530V. I have a 700MHz PIII that has its own widescreen monitor (Sony Vaio), but this would be fine for another Win98 or similar build as well (or the OS/2 machine I keep promising myself). Needs a little more cleaning but works well enough.
Not done running cables so it's a mess. And yes, I have 55 tabs open, and no icons on my desktop.
I have a few of these tiny Dells, my XP build bluescreened on me while booting for this test so I had to use another one, now I'm worried I'll lose that drive, which contains the last version of Steam before XP support was dropped, and a bunch of games. 😒
I really need to spend a lot of this month reorganizing and separating the metaphorical wheat from the metaphorical chaff. I keep threatening to do this and not doing it, but we'll see if I'm consistent. It will be easier to take pictures (and eventually video) if it's less chaotic.
There's also a Sony CPD-L181 from about the same time period that I could never have afforded back in the day (I'm pretty sure I was still using CRTs until close to 2010, still miss those lightweight Dell 19" CRTs). Missing the plastic back cover for the stand and "probably doesn't work and the screen is damaged." I don't know what it is but I had to have luck somewhere! Seems like most of my broken junk works.
The scuffs on the screen and left side in the pic actually cleaned off without shining up the surface, looks nearly new! The Sony might end up on my desk as it has two VGA connectors you can switch between. It actually has a VESA mount.
I was thinking a early/late setup for the Sony, so maybe the PII on one input and a P4 or Athlon on the other? Maybe the Socket 423 P4, because quirky. (I have 2 socket 423 mobos now, and I repaired the broken cooler bracket on the first one.)
So that's 4 Sony and 4 Dell XPSes. I have these accidental collections that start for some reason. I seem to recall from old threads someone had one XPS from each generations, that would cover a lot of computing history, back to 1993 (or 1990 if you count systems with that order code but not sold under that name).
