Reply 180 of 2674, by K.A.R.R.
its a normal hdd with ntfs
os is w10 pro
seems the command does not work
i got this messages
but the 64 bit version works
so its not a big deal
but with fsmp and loopmidi and sound canvas va i have some probs with dosbox
i tested just a few games:
the 7th guest works without probs
wing commander pirvateer works also perfect
but:
test drive 3 creates strange tones when i use fsmp with "use patch info for capital tone fallback" enabled
i have to disable it and press reset ones even when it is disabled to make midi sound ok with test drive 3
wing commander 2 (deluxe cd version and floppy version)
midi sounds not good wrong instruments are used
(with savi host sound is wrong too)
privateer 2
with soudblaster and with gravis ultrasound midi works
but with general midi and soundcanvas midi works in setup porgramm
but game hangs during the 3rd video to joes bar
(at that point no midi is played, so a crash there makes no sense to me)
i have to test if it will crash with normal ms wavetable synth
i can record the wrong test drive 3 and wc2 music
