Reply 20 of 27, by Jorpho
- l33t++
There are some patches at Frogger that might fix the music problem.
Otherwise Windows XP mode (or another virtual machine) is probably the only way.
Frogger isn't playing CDA even in Xp. So - Xp mode isn't solution.
XP mode won't let you use 3D acceleration. Have you tried compatibility modes or selecting a diferent renderer, if available?
wrote:Frogger isn't playing CDA even in Xp. So - Xp mode isn't solution.
That would fit with what the other thread says about changes between DirectX versions.
wrote:XP mode won't let you use 3D acceleration. Have you tried compatibility modes or selecting a diferent renderer, if available?
What would that have to do with CD audio?
I haven't seen he's got it working already. Compatibility mode may fix some CD related problems.
wrote:wrote:Frogger isn't playing CDA even in Xp. So - Xp mode isn't solution.
Not directx. Winmm.dll is the cause. Xp version is trimmed and don't have some of the needed functions.
wrote:I haven't seen he's got it working already.
wrote:so i got it to work without dosbox or nglide
wrote:wrote:wrote:Frogger isn't playing CDA even in Xp. So - Xp mode isn't solution.
Except the Winmm patch does not fix the problem in question.
That CDDA patch linked to works for me in Windows 7 with a later European re-release of Frogger. So I assume the guy who wrote the patch knows what he's talking about.
If you like the game making a backup of that patch is probably a good idea, things like that tend to disappear.
