Reply 20 of 27, by Hoping
Well, it fairly stupid to run a CPU without any kind of cooling, but like the brilliant guys of tom's hardware that did the famous video, there are other ones capable of being so brilliant to do it. Slot 1 PIII didn't had any overheat protection. My girlfriend had a PIII 550 slot CPU that died because the fan died. So, for sure at least Slot PIII CPUs rely on the motherboard.
Reply 21 of 27, by The Serpent Rider
That's would be scenario of unproper cooler installation. Although frying CPUs by cooler removal while running Quake 3 aren't the same thing as accidentally booting system up without one.
Reply 22 of 27, by Hoping
I think that only punting a heat sink on top of the cpu already gives time for the motherboards to shutdown. I think that the protections of that time where only for the scenario of a fan failure. But Tualatins are newer, have a heat spreader and also the motherboards are newer. So I think it's hard to burn a Tualatin but I will not try it because I have more AMD cpus of that era.
Reply 23 of 27, by pshipkov
Just yesterday i had two Tualatins burning at 100+C for over 30 minutes because got distracted for a moment and forgot to connect their plugs.
When i came back i couldn't touch the heatsinks.
The interesting thing is that the CPUs were functioning during the fry-time.
retro bits and bytes | DOS media library
Reply 24 of 27, by The Serpent Rider
Coundn't touch heatsinks != 100+ C.
Reply 25 of 27, by Hoping
And the motherboard didn't shutdown because of overheating? Lack of protection or disabled in bios?. I remember that back then I had a Soltek SL75-KAV and enabled the shut down for cpu fan fail and the board wouldnt boot because I forgot that it had a fan speed controler and wasn't conected to the cpu fan header. That was common on that years. Before when the common motherboards started to control the fan speed.
Reply 26 of 27, by pshipkov
When the incident occurred the board was already running. The intention was to disconnected the fans for a moment only, but that turned into 20 or so minutes instead.
The board beeped at some point which got my attention. Turned it off immediately.
Decided to turn it on with the fans running to cool things down quicker.
Something like 2 minutes in i measured the temperature - it was 80-something C.
Obviously, i won't be verifying the temperature readings with another empirical test. 😁
Reply 27 of 27, by Disruptor
As far as I remember, P4 cpus throttle, P3 cpus halt and can be rebooted after cooling down, and Athlon dies burn.
However, I do not know which core types and revisions are meant.
