Reply 20 of 57, by weedeewee
ThinkpadIL wrote on 2021-10-15, 19:42:
Looks like there is no way to add a "regular" USB connection for hopeless devices like HP 200LX and for each purpose you have to find a specific way. 🙄
If it has an ISA bus, accessible in some way, then you could add a USB connector for storage devices using the CH375 chip. Although it will be abysmally slow. 😀
Do not ask Why !
Reply 21 of 57, by ThinkpadIL
weedeewee wrote on 2021-10-15, 20:16:
MSD.EXE says Bus Type: ISA/XT/Classic Bus
Reply 22 of 57, by SScorpio
As mentioned keyboard/mouse could be tricky.
If it ends up being just for storage, could PCMCIA CF or SD reader work? I'm not sure what you'll have to do to get those mounted in DOS though. Most older packaging for them mentions at least Win9x.
Reply 23 of 57, by ThinkpadIL
SScorpio wrote on 2021-10-15, 20:44:
As for HP 200LX, one of the most hopeless MS-DOS computers, PCMCIA ATA Flash Cards and CF Cards via PCMCIA work just fine.
Reply 24 of 57, by weedeewee
ThinkpadIL wrote on 2021-10-15, 20:56:
I don't know about the hp 200LX.
Do you know about the Atari Portfolio ? 😁
Do not ask Why !
Reply 25 of 57, by ThinkpadIL
weedeewee wrote on 2021-10-15, 21:03:
Well, I'm not crazy enough yet to buy Atari Portfolio, nor HP 95LX 🙄... but yes, of course I know about them 😄
Reply 26 of 57, by weedeewee
ThinkpadIL wrote on 2021-10-15, 21:07:
HP-95LX is still a beast compared to the atari portfolio 🤣
Do not ask Why !
Reply 27 of 57, by Errius
cyclone3d wrote on 2021-10-15, 19:09:
Microsolutions also made a parallel port external HDD back in the day. I have one, but have never used it. No idea what the max size the Microsolutions adapter supports.
I used to have a H45 QuickDrive parallel port enclosure which supported 1 IDE drive. But yes, there was a problem using drives over about 8 GB IIRC. I think they worked but you could only format them to that size.
Is this too much voodoo?
Reply 28 of 57, by Oldskoolmaniac
https://www.ebay.com/itm/194213649176 <--- This works great on my old win95 ibm laptop it shows up as a secondary hard drive
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 29 of 57, by ThinkpadIL
Oldskoolmaniac wrote on 2021-10-16, 00:12:
Yes, this one works fine even with HP 200LX under MS-DOS 5.0. I have one.
Reply 30 of 57, by Jo22
The HP200LX seems to have a PCMCIA slot, so it might be possible to install an USB PCMCIA card.
Together with matching drivers (PCMCIA card services or PC Card services etc) it might run on the 200LX.
That being said, it's not too easy to find something on the web.
Google nolonger obeys the quotation marks the way it used to, so searching explicitly for "USB 1.0" or "USB 1.1" cards shows results for newer USB controllers for Cardbus, too.
(I used "usb 1.1 pcmcia 16-bit")
https://retrocomputing.stackexchange.com/ques … ard-16bits/8695
http://eab.abime.net/showthread.php?t=75688
Reply 31 of 57, by Bondi
Jo22 wrote on 2021-10-16, 04:59:
The HP200LX seems to have a PCMCIA slot, so it might be possible to install an USB PCMCIA card. Together with matching drivers ( […]
200LX has 16 bit PCMCIA port. Unfortunately 16 bit PCMCIA USB cards do not exist. All of them are 32 bit Cardbus cards (with copper stripe and bumps on the connector edge). One can sometimes see USB cards with no bumps, but that's just an old case, guess for cost saving. These are also Cardbus cards.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 32 of 57, by Jo22
According to the Amiga folks, there was that CFU950 chip for 16-Bit PCMCIA,
but actual cards using it became very rare. 🙁
https://www.alldatasheet.com/datasheet-pdf/pd … XCFU950_07.html
Maybe using Compact Flash cards is an alternative.
They are kind of pin compatible to PCMCIA, but shorter/smaller?
Well, there are CF-PCMCIA adapters
Back in time, I had a WLAN (WiFi) CF card for my HP Jornada PDA.
It was in the early 2000s, I vaguely remember. When people used 802.11b and WEP64 or WEP128 encryption still.
Reply 33 of 57, by lolo799
ThinkpadIL wrote on 2021-10-15, 19:25:
cyclone3d wrote on 2021-10-15, 19:18:
What exactly are you looking to hook up via USB in DOS then? Are there DOS drivers for these USB devices you want to use?
Other than storage devices? Keyboard for example.
There are ways to connect a keyboard to the 200LX, one of them being infrared, the other via the serial port, the latter is also true for mice.
Reply 34 of 57, by ThinkpadIL
As Bondi has mentioned above, those are CardBus PC Cards and they are not compatible with HP 200LX PCMCIA slot.
Though there were some interesting Japanese CF to USB adaptors (see attached) but those were intended to work with PDAs and Windows and were intended to be used with Mass Storage Devices only.
    14.22 KiB
    54.27 KiB
Reply 35 of 57, by ThinkpadIL
Jo22 wrote on 2021-10-16, 11:18:
According to the Amiga folks, there was that CFU950 chip for 16-Bit PCMCIA, but actual cards using it became very rare. 🙁 […]
Well, CF Cards of course a great alternative to USB Disks-on-key, but adding USB connection (even if for Mass Storage Devices only) is a nice challenge. 🙂
Reply 36 of 57, by ThinkpadIL
lolo799 wrote on 2021-10-16, 13:43:
Yes, of course. There was a company that was selling Apple Newton keyboards specially modified to be used with HP 200LX, and regarding using an infrared keyboard I've read in Japanese HP 200LX Hardware Bible book.
But still, using an "ordinary" IBM PC compatible keyboard is much more convenient way from my point of view.
Reply 37 of 57, by Grzyb
ThinkpadIL wrote on 2021-10-15, 13:25:
Serial-to-USB
For mice only...
https://github.com/mborjesson/USB-Mouse-to-Serial
https://www.versalent.biz/usbm232.htm
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 38 of 57, by weedeewee
Grzyb wrote on 2021-10-16, 16:22:
Nice, though that first one... using a Raspberry Pi seems a slight bit overkill 😀
Do not ask Why !
Reply 39 of 57, by cyclone3d
Not really. It has to be fast enough to translate the USB protocol to serial.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
