Reply 35520 of 60060, by Horun
- l33t++
Mephusto wrote on 2020-08-18, 16:30:more of the pictures caused they wouldn't all fit. From what I can tell it might be a 486 under the heatsink. The XC87SLC-33 app […]
more of the pictures caused they wouldn't all fit. From what I can tell it might be a 486 under the heatsink. The XC87SLC-33 appears to be a maths coprocessor for a Cyrix or Texas Instruments 486 i think from the info i can find online. It said something about a hybrid 386/486 but i got lost at that point
edited for more info instead of making another post
"psu.jpg"
cant figure out this psu
That was common back in the 90's, would label all the variants. It could be any one of those models/wattage. You would need to remove it and check for other labels which should tell which it is. Even if just a 150 watt is more than enough for any 386 as long as you do not load up too many harddrives. I would remove the PSU and check it over well in and out, would examine the insides carefully for bulging/leaking caps, etc (and take hi-res pictures too)...
