Reply 40 of 49, by wd
can u tell me more what should i need to do ?
1st READ.
2nd:
mount c d:\
1st READ.
2nd:
mount c d:\
wrote:1st READ. 2nd: […]
1st READ.
2nd:mount c d:\
i feel much sorry for all coz my english is not good....
i have problem again ,
the dosbox said illegal command
dir*exe
have i any mistake ?
what i need to type ...???
No need to be sorry, everything's fine 😀
dir*exe
That's why i said you should read. The exact commands are important:
dir *.exe
(note the space and the dot).
wrote:No need to be sorry, everything's fine :) […]
dir*exe
dir *.exe
thz !!
i feel happy ...coz i can do this..
what should i type after?
Try cm2e8
You have too many things mounted, and it is mounted wrong.
Do this (and only type the things that is written in bold, dark letters):
?:\>Z
Z:\>mount -u C
Z:\>mount -u D
This got rid of your old and wrong mountings of C and D. Now we do the correct mounting of C:
Z:\>mount C D:\
Z:\>C:
And now we C(hange) to the D(irectory) where your CM2 game is:
C:\>cd CM2
C:\>dir *.exe
C:\>dir *.bat
C:\>CM2
_________________
wrote:Try cm2e8
ok , i can play CM2 now...I wait it for a long time...
i' m very happy now...thank you all brother....
i want to ask  more questions...
how can i use full screen to play it ?
where can i see the instruction about it ?
How to increase the speed of the game ?
Read the links that MiniMax posted, along with the dosbox README file.
I'll work with you.
Still having the (seemingly) classic problem.
I can run the go.exe file, but not the CM2.exe.
Can anybody help me with this "Stack fault". I have installed the game with the orig CD. It tries to load with the command:-
mount D D:\ -t cdrom -label CM2_96_97
I have tried different cycles setting:-
cycles 6000, 20000, 30000
cycles fixed 6000, 20000, 3000.
I still get getting this stack fault, any ideas.
