Reply 40 of 56, by feipoa
- l33t++
Considering that the inability to overclock occured at the same time as using the incorrect RAM, I'd say that your memory controller has some questionably burned out transistors due to overcurrent (inside the chip). Depending on how long you had the wrong voltage RAM in there, the memory controller (Northbridge) may always act flakey. Surprisingly, the M919 I put the wrong RAM into 10 years ago works a little better now than it used to. You may need to reduce the cache wait states to get the board stable again.
This same principle can be applied to CPU's as well, which is why I don't like to run them at a voltage much higher than they need. For this reason, I use a variable voltage regulator on the CPU's to find the lowest possible voltage the CPU will run at stably while not overheating (aka, the sweet spot). It is quite a tedious process, but for these overclocked Cyrix CPUs, it is somewhere between 3.65 and 3.95 volts. I've got a thermocouple probe at the base of my Cyrix right now for characterisation.
Since you are using a Shuttle HOT-433 v4, your Northbridge memory controller is likely a UMC 8881F. These are not produced anymore, but you can probably desolder them from other motherboards. To properly remove SMD chipsets, you need a rework station, perhaps like this one,
http://www.youtube.com/watch?v=VySTIRoPtt4
Or you can use flux and a wick like this guy,
http://www.youtube.com/watch?v=0EUAEtri3h0
Before going to all this hassle though, have you thoroughly tested the motherboard and determined it is a failed memory controller? What happens if you put in an AMD X5 at 133 MHz and run it with 2-1-2 and 0ws/0ws (using 3.45 V)? Have you reset the BIOS with the reset jumper?
I think the HOT's prefer paired RAM, are you using FPM RAM in pairs? Two sticks of 60ns, low density, 8 MB RAM modules would be good for testing this.
