Reply 41600 of 53040, by RaiderOfLostVoodoo
- Member
I won an auction for a scrap lot for 30€.
Most interesting piece: A Voodoo 1 from Diamond. Gotta have to earn my name!
Lets hope it works or can be restored.
RaiderOfLostVoodoo wrote on 2021-12-20, 11:34:I won an auction for a scrap lot for 30€.
heh hope so, cant let a good Voodoo go to scrap like that.
TrashPanda wrote on 2021-12-20, 11:38:heh hope so, cant let a good Voodoo go to scrap like that.
Just what I thought!
There was another lot from another seller. 10kg of scrap. Also with a Voodoo 1. But that went for 70€.
Also the moron ripped out the socket with the CPUs, cuz time is money! -.-
RaiderOfLostVoodoo wrote on 2021-12-20, 12:52:Just what I thought! There was another lot from another seller. 10kg of scrap. Also with a Voodoo 1. But that went for 70€. Also […]
Would take more time to rip it out than to just take the cpu out, them sockets are sturdy.
Few days ago met another local retro-pc (and some consoles) person, who gave me a Trio32 VLB videocard, which was a good improvement over my CL-GD5429 based VLB card on my 486 pc. (Quake benchmark went from 16.1fps to 16.5)
Even though he just gave it to me, i promised that this is not the end of the deal and soon we'll find something i have and he needs. 😀
Today I got the present of one of my colleagues, one Amiga 1200.
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower (x2), Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
Wow, thanks for the photos ! I'm glad that it still works. It will serve you well ! 😀
I managed to pick up a Twin Turbo 128 graphics accelerator for PowerMac models that I don’t yet own. Sure it could be put in my G3, but there’s no point to that really.
My 7100/80 is nubus only as well, so literally nothing can put this to actually useful use.
Bondi wrote on 2021-12-12, 08:18:bjwil1991 wrote on 2021-12-12, 07:11:Bought/won a pair of MediaVision LPT sound cards on eBay. […]
Seller's photos:
The yellowed one needs attention and the other needs a good sticker residue removal. Going to test them on a laptop that has a crappy sound card.
A good buy! I saw this listing, but did not realize it was for two devices.
Audioport has a Yamaha OPL chip and Sound Blaster support, but IIRC SB works only in Windows. Please keep us posted on testing results.
I got them this afternoon and sadly, I cannot find the drivers that'll work with WFW 3.11 at all. When I try to run the install program, it says to run the Multimedia Extensions first.
Any idea of how to fix that?
bjwil1991 wrote on 2021-12-21, 06:37:Bondi wrote on 2021-12-12, 08:18:bjwil1991 wrote on 2021-12-12, 07:11:Bought/won a pair of MediaVision LPT sound cards on eBay. […]
Seller's photos:
Audioport has a Yamaha OPL chip and Sound Blaster support, but IIRC SB works only in Windows. Please keep us posted on testing results.I got them this afternoon and sadly, I cannot find the drivers that'll work with WFW 3.11 at all. When I try to run the install program, it says to run the Multimedia Extensions first.
Not sure what the problem is. I tried to install the attached drivers to WIN 3.11 in DOsbox and they insatlled with no issues.
The only guess I have is that it needs Windows Sound System installed first.
I got it to install (the drivers using the control panel) after I got the power brick situation fixed.
Good news: it works in WFW 3.11
Bad news: doesn't work with DOS anything still and the install.exe doesn't work still.
I have a hunch that I need the 3 diskette set to get the adapter to work correctly.
bjwil1991 wrote on 2021-12-21, 08:21:I got it to install (the drivers using the control panel) after I got the power brick situation fixed. […]
I'm sure someone on the forum has a complete set. Cyclone3D IRRC had one.
OMORES wrote on 2021-12-19, 13:15:This Number Nine video card (Savage4 Xtreme) with an unusual DVI to VGA implementation...
The card works!
Working…. Eight days a week!
Look closely against a light 😉
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
I received my last Mouser order today. Yummy organic polymer capacitors from Kemet and Nichicon for recapping two DFI K6XV3+ / 66 mainboards.
This Sun motherboard with 512MB SD-RAM and a 440Mhz UltraSPARC CPU...
The ATX connector looks like a very standard one, but it's not ... (or maybe I have to try an older PSU)
bjwil1991 wrote on 2021-12-21, 06:37:I got them this afternoon and sadly, I cannot find the drivers that'll work with WFW 3.11 at all. When I try to run the install program, it says to run the Multimedia Extensions first.
Working with a rusty memory here, haven't done it recently, but I think you need to go to control panel and install the windows components that support sound and multimedia. (Will need the disks or a directory with all the .cab files)
edit: derp, guess you did that, just read following posts.
OMORES wrote on 2021-12-21, 14:03:This Sun motherboard with 512MB SD-RAM and a 440Mhz UltraSPARC CPU...
Nice board. The connector looks very similar to the ones Dell had: A Permanent Solution to the Dell 'Fake ATX' Power Supply Problem?
Sure it's not ATX? Did you have the AUX connector plugged in too? If not, that's your problem.
Here's a pic of an Ultra 10 with PSU hooked up:
And here's ATX pinout:
Perfect match with the ATX 1.x 20p connector. But that AUX-connector next to it is non-optional on the Sun systems.
Hirsch wrote on 2021-12-21, 12:43:I received my last Mouser order today. Yummy organic polymer capacitors from Kemet and Nichicon for recapping two DFI K6XV3+ / 66 mainboards.
Looking forward to receive my K6XV3+/66 back. 😀
Not exactly computer hardware or my own purchase, but a friend I forward stuff to from here in the UK just bought me 3 sets of metal shelving to finish reorganising my collections. An awesome gesture from someone I only know online.
https://www.ebay.co.uk/itm/222779509044 (I hope it's OK to post a link showing what shelves I use)
