Reply 640 of 755, by feipoa
- l33t++
Chadti99 wrote on 2022-03-18, 12:54:feipoa wrote on 2022-03-18, 11:45:From my experience: with a cool head and a fresh scalpel, there's a 50% chance you break only 1 clip. Practice on a dead board. Check your box of dead boards to see if you have a spare top. Brand A top sleeves don't necessarily fit brand B's.
EDIT: I've taken off quite a few of these because previous owners like to jamm in CPUs with bent pins. Those bent pins mess up the sockets inside and they need to be bent back into place without the top sleeve on.
Not to go too far off topic but how did you diagnose bent socket pins or was it a hunch from experience? Did you use a post diagnosis card?
If you insert a CPU with perfectly straight pins into the socket 3 and there are areas where the CPU won't sit flush, then that zone of the socket is bent inside or there is some debris in there. In most cases, you can fix the existing female socket piece by bending it back into shape, but in other cases you cannot, and will need to desolder that one particular piece of metal.
