Reply 640 of 1037, by red-ray
Camtheman wrote on 2020-09-11, 08:52:
Needless to say there's quite a bit missing. Can't read the bios date among many other things.
Thank you for the report and the BIOS date is missing as SIV does not have a VXD for Windows 9x, were you to boot Windows NT then the BIOS date should be reported. In general Windows 95 does not have many of the SetupAPI routines SIV needs and with NT4 or W98 SIV would do better. The other issue is that the system has IBM MicroChannel (MCA) rather than PCI and SIV has no MCA support at all. Looking at the CPUZ report you posted neither does CPUZ.
From checking https://www.geoffchappell.com/studies/windows … story/index.htm I suspect NT4 is the last version of Windows to support MCA, is it?
Reply 641 of 1037, by mastergamma12
I'll be testing a DFI LanParty UT X58-T3eH8 once I get it. It's going to replace my 790i FTW.
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 642 of 1037, by red-ray
mastergamma12 wrote on 2020-09-11, 19:03:
OK, SIV does not have any explicit DFI LanParty UT X58-T3eH8 support so expect I will need to make adjustments for the ITE IT8718F SIO, it's also possible the system may have a PWM power controller, but won't know 'till I check the save file.
All the x58/Bloomfield/Gulftown support should be fine as I have an ASUS P6X58D Premium system.
Reply 643 of 1037, by Camtheman
red-ray wrote on 2020-09-11, 10:11:
I believe it is the last yes. IBM PS/2s have two BIOSes, one Advanced BIOS (for OS/2)and one Legacy for MS-DOS, 9x, etc. SIV would read the Legacy one I assume? Interesting stuff.
Early 90s: IBM PS/2 Server 95/A, Pentium 66, 16MB RAM, XGA-2, IBM SCSI Corvette, SCSI2SD, 3 Com EtherLink III MCA, Resound 2 AdLib MCA
Late 90s: Micron Millenia MXE, ABIT VH6-II, Coppermine 1ghz, 1024MB, Voodoo 5 5500 PCI, GUS Max 2.1, 128GB SATA PNY SSD
Reply 644 of 1037, by red-ray
Camtheman wrote on 2020-09-12, 12:45:
Were you to boot Windows NT 4 then SIV should read 128KB starting from physical address 0xE0000 and then search this for all the BIOS tables which on NT/XP systems are reported via Menu->Hardware->BIOS Tables->BIOS Tables. Ideally there would be "_DMI_" information, but I suspect the BIOS may be too old to have this, epically so given CPUZ did not report the motherboard name. On systems running NT then the save will generate both .TXT + a 128KB .DMI file and if I had the .DMI file I suspect I would be able to get SIV to report more about the system. Have you ever had Windows NT running on the system?
Reply 645 of 1037, by Mumak
Tested this on my IBM PS/2 Server 95/A with the following specs: […]
Pentium 1 @ 66mhz
16 MB RAM
IBM XGA/2 1MB Graphics
IBM SCSI-2 "Corvette"
Adlib Clone card
3Com EtherLink III MCA
HWiNFO DOS version has MCA support. I'd be happy to get a report from that system.
Reply 646 of 1037, by mastergamma12
I'll post on the DFI X58 in a few hours. Gotta reinstall windows.
Reply 647 of 1037, by mastergamma12
Here's the SIV results from the DFI LanParty UT X58-T3eH8 including a bios screenshot
file.php?mode=view&id=92378
file.php?mode=view&id=92379
    1.01 MiB
    704.6 KiB
    SIV_FINAL-LAN-PARTY.zip
    323.77 KiB
    50 downloads
Reply 648 of 1037, by red-ray
mastergamma12 wrote on 2020-09-18, 00:08:
Thank you for the save files and remembering the BIOS screen shot which made things easy. How does the attached SIV64X 5.52 DFILP-09 test SIV look to you please?
Reply 649 of 1037, by mastergamma12
Here
file.php?mode=view&id=92395
    689.84 KiB
    338.97 KiB
    46 downloads
Reply 650 of 1037, by red-ray
mastergamma12 wrote on 2020-09-18, 07:20:
Here
All looks good and I have now released SIV 5.52 Beta-09 so please update.
Is your DFI x58 the very last DFI Lan Party that was made please?
Reply 651 of 1037, by mastergamma12
red-ray wrote on 2020-09-23, 19:06:
Here
AFAIK it's either this or the P55 one, though AFAIK this can run a 980x or 990x but I'll confirm that once my 980x gets here so it may not be the last one but it could make it the most powerful one.
Reply 652 of 1037, by red-ray
mastergamma12 wrote on 2020-09-24, 00:51:
AFAIK this can run a 980x or 990x but I'll confirm that once my 980x gets here.
Thank you, looking at Menu->Hardware->BIOS Tables->BIOS Tables the DFI BIOS only contains the Intel (Gulftown) [B0] microcode, but my 980X is stepping [B1] so I guess it may depend on which stepping you get.
On my 980X system the Revision 001F µCode Dated 2018-05-08 get's used, as I recall I found a modified BIOS which contained the updated CPU µCode a couple of years ago and wonder if there is one for the DFI.
After a Google I found https://www.techpowerup.com/forums/threads/me … s.246101/page-8
Reply 653 of 1037, by mastergamma12
red-ray wrote on 2020-09-24, 06:21:
Thank you, looking at Menu->Hardware->BIOS Tables->BIOS Tables the DFI BIOS only contains the Intel (Gulftown) [B0] microcode, b […]
I came across this
index.php?s=0311ef0034eee89d9674e4124e1cdc34&act=Attach&type=post&id=4490647
Looks promising if real.
And here's the link to where I got it
https://forum.lowyat.net/topic/3598408
Reply 654 of 1037, by red-ray
mastergamma12 wrote on 2020-09-24, 17:07:
I suspect it is, but wonder which CPU µCode is being used. My guess is that the system will post with the 980X (when do you expect it?), but will not be using the latest CPU µCode unless you run Windows 10.
Reply 655 of 1037, by mastergamma12
red-ray wrote on 2020-09-24, 20:05:
USPS says Monday but it looks like either tomorrow or saturday.
I'll check with SIV if it works.
Reply 656 of 1037, by red-ray
mastergamma12 wrote on 2020-09-24, 20:25:
Comparing with my system which is as below yours does not have the latest Intel (Gulftown) [B1] + Intel (Bloomfield) [D0] CPU µCode .
file.php?id=92875
    240.18 KiB
    Intel Core i7 Extreme 980X (Gulftown) 3.33GHz [B1]
Reply 657 of 1037, by mastergamma12
red-ray wrote on 2020-09-25, 07:17:
Comparing with my system which is as below yours does not have the latest Intel (Gulftown) [B1] + Intel (Bloomfield) [D0] CPU µC […]
file.php?id=92875
Well it works, I did a bios update to that Spectre/Meltdown one, SIV64 reports it's using the b1 microcode, I'll upload the stuff later.
Also the ram automatically runs at 1600 mhz now.
Also SIV thinks it's running at 2.93 like the W3540 but CPU Z and AIDA64 show 3.33ghz.
Reply 658 of 1037, by mastergamma12
Here
file.php?mode=view&id=92909
file.php?mode=view&id=92910
    1.06 MiB
    1.31 MiB
    343.22 KiB
    47 downloads
Reply 659 of 1037, by red-ray
mastergamma12 wrote on 2020-09-25, 16:49:
Here
To me it looks like the BIOS is setup to underclock your 980X, is this intentional?
file.php?id=92920
    73.01 KiB
    980X setups
