Reply 80 of 174, by feipoa
- l33t++
Way before CPU galaxy's video was this link detailing the DLC/SXL settings, Register settings for various CPUs It goes into much more detail.
Mine also refused to work with a 16 Mhz FSB when I first tested it. Either the system didn't like the 3-chip memory I had installed, or somehow the presence of the FPU allowed it to 16 MHz FSB. When I first tested it, 12.5 MHz was max. Not any longer.
Yeah, it looks like aliexpress has the 87SLC-33QP chips for $10. I'm not sure if they are fake. I'll report back when mine arrives. I plan on doing more testing with the -v25 I have on there now, but upon initial tests, the surface isn't getting hot. It was only $5, so not much loss to replace it.
According to Anonymous Coward, the non -v and non-g50 SXL2-40's should also be 5 V, so I might try this as well. Also, the SLC2-25/50 should be 5 V and might be worth testing. According to Anonymous Coward, they are locked in clock doubled mode. Cheapest I could find is $57 each from China. Not sure if they are authentic or not. Best would be a desolder, but I couldn't find any.
I've given up on the 286 no floppy boot issue. I plan to use the SuperChip anyway. I have an LS-120 BIOS I might try on a Lo-Tech card, but my LS-120 is sitting at AVICC, so cannot test it yet. But this might allow for 286 booting on the floppy.
