First post, by AppleSauce
Has anyone had luck with using the 44 to 40 pin adapters.
I grabbed a msata to 44 pin ide then connected it to the 44 to 40 but it won't see the drive in the autodetect.
1.81 MiB
Reply 2 of 4, by AppleSauce
jmarsh wrote on 2024-04-22, 08:11:
Pin 1 is at the opposite end of the 44-pin connector from the power - judging from the red stripe you've got the IDE cable connected the wrong way around.
The connector is keyed though , there's only one way to plug it in.
1.55 MiB
Reply 3 of 4, by AppleSauce
Also does anyone know how to configure the jumper block for the 44 pin drive?
Like which ones slave which ones master?
648.27 KiB
