Voodoo 3 Shootout
First post, by mwdmeyer
Hi All,
I have every (I think!) Voodoo 3 video card from a Velocity 100 through to a Voodoo 3 3500 and wanted to compare all of the different configurations including: PCI vs AGP, 1 vs 2 TMU, 8MB vs 16MB VRAM, SGRAM vs SDRAM, Core/Memory Scaling and CPU scaling.
I've put together all of the information into a youtube video but have also include the PDF slides with graphs and also raw results in excel.
I tested Quake 2, Quake 3, Unreal, 3dmark2000 & Expendable.
I hope it is of interest to some people! Welcome any feedback (good or bad!).
Youtube Video: https://youtu.be/Ss9vDF_FNfI?si=jU2uXfoFRau7YNGU
PDF slides: https://www.vogonswiki.com/images/e/ea/Voodoo_3_shootout.pdf
Raw Results: https://www.vogonswiki.com/images/1/12/3dfx_V … 3_Shootout.xlsx
Reply 1 of 5, by Ozzuneoj
Nice work! I especially appreciate the SDRAM vs SGRAM benchmarks, as well as the Velocity 100 comparisons. Definitely looks like an 8MB Velocity 100 with the 2nd TMU enabled is a solid card to get high frame rates from older (pre-1999) games at moderate resolutions without having to spend so much on a 16MB V3.
Reply 2 of 5, by mwdmeyer
Thanks & agree, the Velocity 100 is a great fast card if you can stay in the 8mb vram limit, and for glide that seems no issue.
Reply 3 of 5, by Joseph_Joestar
Very interesting results! Especially the PCI vs. AGP comparison.
One small note, if I may. For the CPU speed comparison (500 MHz vs. 1 GHz) it would have made more sense to use a lower resolution like 640x480. With 1024x768 you will likely get GPU bottlenecked on Voodoo 3 cards.
Reply 4 of 5, by pshipkov
Cool.
One takeaway from the numbers is that the system is CPU limited and the V cards are slacking most of the time.
May be good to spin them with faster CPU one day.
retro bits and bytes
Reply 5 of 5, by smola
Great comparisons. I'd add 640x480x16 modes and please, convert textured pictures from bars in pdf to ordinary squared colored boxes. Now pdf has 44MB, it's total overkill where should have less than 100kB. Cheers 😀
my repairs: mobo index :: vga index :: requests
