First post, by GabrielKnight123
I have a socket 3 motherboard with my first time using a bevel tip for thin trace repairs I have managed to use a wire to bridge a broken trace but for now its only soldered to the trace and not fixed to the board, if the wire was to be knocked or bumped I'm sure the original trace would lift off with the wire, is a good way to secure it to use common superglue? I'm not sure though because if the superglue or wire needs to be removed later wouldn't the glue make more trouble than good.
Reply 1 of 2, by Shponglefan
Since the wire is pinned beneath the DIP socket, it's probably fine as is.
If you're really worried about it, you can add some solder mask to cover the exposed metal wire and solder joints. Beyond that, it's likely fine.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
