NVIDIA GEFORCE4 MX4000
First post, by rain
hi ive NVIDIA GEFORCE4 MX4000 card. installed nvidia_9x_56.64 drivers but all Thief games including 1-2 not work. gives me black screen. but other games like fifa 2001 , motocross madness2 works fine. is this card has problems with thief games? thanks
_retired retro pc user_
Reply 1 of 9, by smtkr
Those games are finicky. I've had this issue with a Geforce 2 and then it resolved after an OS reinstall (which likely wasn't the issue because I might have used different drivers between installs and possible different DirectX versions too). I know that's not very helpful, but if the card works fine for other stuff, you probably have some software issue, so start experimenting. Also, if you can, use Windows XP.
Reply 3 of 9, by Joseph_Joestar
rain wrote on 2024-06-27, 16:36:
From what I remember, Thief 2 doesn't like Nvidia drivers higher than 45.23 under Win9x.
However, this tweak should be able to solve the issue.
Reply 4 of 9, by rain
Joseph_Joestar wrote on 2024-06-28, 06:41:
45.23 is not for mx4000 . cant install
Reply 5 of 9, by Joseph_Joestar
rain wrote on 2024-06-28, 06:46:
Looks like you did't read the thread that I linked to.
That tweak solves the issue on Nvidia drivers from the 50.xx series.
Reply 6 of 9, by rain
Joseph_Joestar wrote on 2024-06-28, 06:49:
you mean this?
"" For me 53.04 works fine with thief2, dx8.0 and my FX5900 Ultra if 'safe texture manager' in the user.cfg is active (remove the semicolon in front of it), with it disabled I get the black screen you mentioned. Give it a try. ""
Reply 7 of 9, by Joseph_Joestar
rain wrote on 2024-06-28, 07:03:
you mean this?
Yes, that's it.
That tweak worked for me and a few other people in the linked thread.
Reply 8 of 9, by rain
Joseph_Joestar wrote on 2024-06-28, 07:39:
you mean this?
Yes, that's it.
where is " user.cfg "
Reply 9 of 9, by Joseph_Joestar
rain wrote on 2024-06-28, 08:13:
It's a Thief 2 configuration file, and it can be found inside the folder where that game is installed.
