First post, by waterbeesje
- Oldbie
I have this socket 7 board, San Li SL-586V. Is working just fine with a Pentium 166 but the front panel headers don't work at all.
No HDD led
No power led
No reset button
No speaker
Double checked out it could be polarity (turning the connector around doesn't work).
I've tested the LEDs and stuff on other motherboards and they work just fine ( it's a loose bundle of cables for testing purposes).
The board is properly connected to the backplate of my test bench, no grounding issues.
Could this be a quick fix?
I'm gonna sell the board, so I'm not going to put lots of time into it...
Stuck at 10MHz...
