First post, by gryffinwings
Do you guys have any recommendations on a cooler for the AMD Athlon Thunderbird 1000 MHz CPU (A1000AMT3C)? Did these run hot, or will a generic CPU cooler that I find on eBay be enough?
Main Computer: Custom - Intel 12900K, Asus Nvidia 3080 Ti, 64 GB DDR5.
Retro Computer: Packard Bell Legend I - AMD 286, 640KB RAM
Retro Computer: Shuttle XPC - Pentium 4 2.8 GHz FSB 400 MHz, ATi Radeon 9600 Pro, Sound Blaster Live!, 2GB RAM.
Reply 1 of 2, by Repo Man11
I was going to recommend an Adaptec ACC-9500; while it isn't an especially great cooler, it does have a copper bottom and it works pretty well. More importantly, up until fairly recently they were available on Ebay for a pretty good price, but I just checked and that doesn't seem to be the case anymore (maybe they were new old stock and sold out?). An Athlon 1000 is a hot running CPU, but with good case cooling even a basic Socket A cooler should be fine. If it were me, I would try to find something that has a copper base or plug, and use a premium thermal paste.
Reply 2 of 2, by gryffinwings
Repo Man11 wrote on 2024-06-30, 01:30:
Thanks for the advice, I found some AMD OEM heatsinks with the copper core on them; I think that's what I will use; I intended to use Noctua NT-H1 or Thermal Grizzly Kryonaut that I have on hand. For the case, I will be running a Lian-li PC-61; I was able to get one for a decent price, and I'll likely replace all the fans with Arctic P8 80mm fans. I'd love some Noctua ones, but that would be a bit pricey for this project.
