First post, by space_eraser
Hi folks,
Undocumented 512kB WB L2 cache is possible to activate on AB-PB4 v1.3. Then BIOS identifies and posts "Enhanced Write Back Cache" instead of usual "Cache memory 256k" .
Because Ali 1487/1489 chipset supports it, two EDO 72pin double sided SIMM has been used. It seems the memory BW performance can be dramaticaly improved. I have tested enhanced Am486DX4-100 SV8B (Am486DX4-S) and Am486DX5-133W16BGC (Am5x86-P75-S). Both are using WB L1 cache. DX4 has 8kB, DX5 16kB.
Abit PB4 contains single L2 cache SRAM bank only. It consist of 4x original DIP32 Winbond W24512AK-15 L2 SRAM chips, replaced with ISSI IS61C1024-15N and 1x original DIP28 TAG SRAM Winbond W24129AK-15, replaced with UM61M256k-15.
You can see the results and enjoy 😀
