First post, by APOPAP
Hello,
I recently got a ISA sound card (SB pro compatible).
I installed the drivers and tried to play some DOS games.But sound effects (shooting, door opening in doom,etc) are too loud.On the other hand, I can barely hear the music playing in the background.
I tried to change wave and fm settings from the configuration menu but that not helped.
What should I do?
Reply 1 of 16, by feda
Do the in-game volume sliders do anything?
Reply 2 of 16, by zwrr
Have you tried tweaking your SFX Volume and MUSIC Volume in a game like DOOM?
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
Reply 3 of 16, by APOPAP
Thanks for your replies.
When I set sfx volume in doom at it's lowest value,it sounds normally.
But what about games that haven't that option (like wolf 3d)?
Reply 4 of 16, by badmojo
APOPAP wrote on 2024-07-09, 20:11:
This should have helped - maybe you have the wrong mixer software or version of it. What's the sound card? Can you provide a picture of it?
Reply 6 of 16, by zwrr
From the driver file analysis, your sound card is a combination of OPTI 929 and CS4231, maybe you can try to use the same chip driver from other manufacturers? For example, the Acer Magic S20 or MAD16 Pro.
Reply 8 of 16, by ux-3
Your mixer picture shows a mixer set up to do exactly what you observe: Loud effects! Turn wave down, turn FM (or CD) up.
Retro PC warning: The things you own end up owning you.
Reply 9 of 16, by zwrr
APOPAP wrote on 2024-07-10, 08:44:
I ve tried the Mad 16 Pro drivers.Doesn't work
I will try the Acer Magic drivers
http://vogonsdrivers.com/getfile.php?fileid=1966&menustate=0
It may be noted that many OPTI929 drivers correspond to the specified CODEC chip, and some drivers require you to select the correct CODEC model during the installation process, such as CS4231 and AD1845.
Reply 10 of 16, by APOPAP
ux-3 wrote on 2024-07-10, 08:49:
Well,I changed that but now only works in real-mode dos...no dos box
Reply 11 of 16, by ux-3
APOPAP wrote on 2024-07-10, 09:17:
I wonder if DOS box would even assume you have an OPL3 present. It might just output 16 bit generated audio to wave-out as default maybe.
Reply 12 of 16, by APOPAP
ux-3 wrote on 2024-07-10, 12:48:
I see what's wrong.The driver has a file named CSACMOD1.EXE .It is loaded at the config.sys as a device= but that does not appear to work.Only when I start the computer as "command prompt only" seems to load the driver.For "restart in msdos mode" I edited DOSSTART.BAT and added c:\se1440\csacmod1 (device driver path).But now what about dos window?I added the same in Autoexec but not helped.I tried to run the program manually from dos box(CSACMOD1)-but says cannot be run in windows box.
I see there is an option to configure opl3 yamaha synth from control panrel.(I am uploading a photo simillar to that I have(I can't take a photo right now))
Reply 13 of 16, by wbahnassi
For Win 3.x, typically there is a mixer application for Windows. But perhaps running the mixer in a DOS box will work too.
For Win9x, the mixer is just right there on the right-bottom corner of the task bar, and it should allow individual control of Wave/Midi/CD/Line...etc. Those apply to games run in a DOS box.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 14 of 16, by APOPAP
I tried to change the mixer's setting but that unfortunately didn't help.The driver (CSACMOD1.EXE) is present in config.sys (device=C:\SE1440\CSACMOD1.EXE) but the driver seems not to be loaded for a Dox Box(as the real mode dos) .As a result sound effects are too loud and music can barely be heard.I can even hear a little music distortion, something that there isn't when I run a game in Real Dos.
Reply 15 of 16, by ux-3
I would think that the cause is this:
in real DOS, the sound card is used for wave and FM to generate sound.
If you are using DOSbox (the emulator), the sound card only used the wave part to generate all sound. So in DOS, you need a different mixer setting than in Windows/DOSbox. When using a dos window, a third setting may apply, depending on how you boot into windows.
Reply 16 of 16, by APOPAP
ux-3 wrote on 2024-07-11, 09:49:
Yes.Maybe the problem is something like that.
Now,on Real Mode dos the music and sound work great.(After I loaded the driver in Config.sys and dosstart.bat)
In Windows the "Windows sound system" works too.
But,in the dos window (No DosBox emulator) the sound keeps to be too loud and music too silent.
Is there I mixer I must configure or is a driver problem?
