First post, by otacon6530
When I turn on my Wyse 8088 cpu 8bit ISA board it produces 6 rapid beeps then 1 beep. There is no video through the trident 9000i graphics card which is configured to work in 8bit mode and confirmed working with another computer. I assumed it was AMI due to the beep pattern, but after dumping the rom it clearly says it is a Phoenix bios.
Anyone know what 6, 1 beeps at startup could mean? It doesn't repeat.
Here at the post codes at startup in order:
58 - Test interrupts
E9 - Init Multi Processor
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
4B - QuietBoot Start
FE - ?
FE - ?
FE - ?
FE - ?
E2 - Initialize the CPU
FE - ?
FE - ?
FE - ?
FE - ?
FE - ?
66 - Configure Advanced Cached Registers
FE - ?
FB - ?
I am having a hard time figuring out what it is trying to tell me, so any insights would be helpful.
